Home » Language IDEs » ServerTools (WTP) » Error loading tomcat server configuration
Error loading tomcat server configuration [message #216011] Tue, 24 June 2008 18:49 Go to next message
Originally posted by: cuco2772.gmail.com
I was having problems with the ubuntu packaged version of tomcat5.5
loading a blank page so I decided to download tomcat5.5 straight from the
site to the same directory, with a symlink from tomcat5.5 pointing to the
apache-tomcat-5.5.26
install directory so that things that were referencing tomcat5.5 would go
to the directory of the new install instead.
I was successful in adding the New Server runtime but when trying to
define a new
server for the WTP tutorial-1 project I got the following error:
This is in the window that's titled 'New Server'
'Could not load the Tomcat server configuration at
/usr/share/tomcat5.5/conf. The configuration may be corrupt or incomplete.'
Anyone have any ideas on what might be going wrong ? Thanks,
Adam Posner
Re: Error loading tomcat server configuration [message #216018 is a reply to message #216011] Wed, 25 June 2008 08:55 Go to previous messageGo to next message
Adam Posner wrote:
> the site to the same directory, with a symlink from tomcat5.5 pointing
> to the apache-tomcat-5.5.26 install directory so that things that were
> referencing tomcat5.5 would go to the directory of the new install instead.
> define a new
> Adam Posner
See if the following link helps:
http://wiki.eclipse.org/WTP_Tomcat_FAQ#When_I_try_to_create_ a_server.2C_it_says_that_it_.22Could_not_load_the_Tomcat_ser ver_configuration..22_What_is_the_problem.3F
Also, check the Error Log view to see if any more specific information
about the problem is revealed there.
Larry
Re: Error loading tomcat server configuration [message #216074 is a reply to message #216018] Wed, 25 June 2008 17:34 Go to previous message
Thanks, that's very informative and useful info.
Unfortunately I think I may have complicated my situation.
Rather than uninstall the Ubuntu packaged version of tomcat5.5, I
downloaded the
apache-tomcat-5.5.26 from the tomcat site, installed it in the same
directory as the packaged version, then moved the home directory of the
ubuntu tomcat5.5,
(called tomcat5.5) to ubuntu-tomcat5.5. After this I created a symlink
called
tomcat5.5 pointing to the real tomcat install directory,
(called apache-tomcat5.5.26), and proceeded to do the server
configurations for the new tomcat mentioned above within eclipse. Probably
too simplistic of an approach.
My guess is that those 4 configuration files that were mentioned above are
in different locations in the different installs, so eclipse is probably
trying to load the ones from the ubuntu packaged install.
I think I will try uninstalling that one and see what happens.
Previous Topic:[ANN] WTP 3.0 has been released!
Next Topic:Send by HttpClient, receive by IE ?
Current Time: Thu Jul 24 18:41:29 EDT 2025
Powered by FUDForum. Page generated in 0.05092 seconds
