Home » Eclipse Projects » Eclipse Platform » Installing eclipse
Installing eclipse [message #215961] Thu, 25 March 2004 15:55 Go to next message
Originally posted by: mikewiegel.swissonline.ch
Hello
As a newby I have tried to install eclipse-SDK-3.OM7-win32
Java runtime is installed (sev 1.4.2_04)
An error occurs
JVM terminated Exitcode = 1
Somewhere is mentioned showsplash 600
I am not sure or this is the right place to ask
I would be grateful for an answer
Thank you
Mike
Re: Installing eclipse [message #216078 is a reply to message #215961] Thu, 25 March 2004 23:16 Go to previous messageGo to next message
Originally posted by: nrajesh.crimsonlogic.co.in
Hi mike,
When are you getting this error? when opening the eclipse itself or
when opening your application from eclipse?
Rajesh
mike wiegel wrote:
> Hello
> An error occurs
> Thank you
> Mike
Re: Installing eclipse [message #216230 is a reply to message #216078] Fri, 26 March 2004 08:45 Go to previous messageGo to next message
Hi Rajesh
Thank you for answering my question
The error occured immediate when i started eclipse.exe which is in
c:\eclipse
The precise message is
JVM terminated Exitcode=1
C:\windows\system32\javaw.exe
-cp C:\eclipse\startup.jar org.eclipse.core.launcher.main
-os win32
-wr win 32
arch x86
showsplash C:\eclipse\eclipse.exe showsplash 600
My os is windows XP professional
Does this message mean something to you
Thank you
Mike
N.Rajesh wrote:
> Hi mike,
> Rajesh
> mike wiegel wrote:
> > Hello
> > An error occurs
> > Thank you
> > Mike
Re: Installing eclipse [message #216601 is a reply to message #216230] Sat, 27 March 2004 07:15 Go to previous message
You aren't the only one. I get this too, also on XP. My current (given)
answer is to deinstall all my JDK and to reinstall 1.4. (However there are
two at SUN and I'm not sure which one I should use.) Also, I see messages
about 1.5. If I'm going to go through all this trouble, why not wait and
do it once with 1.5?
If you'll forgive my soapbox, having decades of experience with virtually
every OS and hardware except the PC, which I've always regarded as a toy,
I can't tell you now that I'm entering development on PC with PC-tools, it
seems that the answer to any question is to reblast or reinstall or ...
These would never be acceptable answers in the day of MainFrame or Minis.
<sigh>
When I get to it, I plan to remove all JDK, and perhaps even Eclipse, then
install the latest JDK, then install again Eclipse.
<sigh>
-doug
<ps: perhaps "virtually every" is an exaggeration ... <grin>
mike wiegel wrote:
> Hi Rajesh
> c:eclipse
> C:windowssystem32javaw.exe
> -cp C:eclipsestartup.jar org.eclipse.core.launcher.main
> -os win32
> -wr win 32
> arch x86
> showsplash C:eclipseeclipse.exe showsplash 600
> Thank you
> Mike
> N.Rajesh wrote:
> > Hi mike,
> > Regards,
> > Rajesh
> > mike wiegel wrote:
> > > Hello
> > > An error occurs
> > > Thank you
> > > Mike
Previous Topic:error: can't instantiate class
Next Topic:Since M7 Key Bindings don't work
Current Time: Sat Nov 08 16:38:54 EST 2025
Powered by FUDForum. Page generated in 0.03566 seconds
