Home » Eclipse Projects » Eclipse Platform » M7 Merge View??? [Learner driver]
M7 Merge View??? [Learner driver] [message #215801] Thu, 25 March 2004 11:21 Go to next message
Merging in Eclipse < M7 used to be a doddle. Now when I follow exactly the
same procedure in M7 (right click on target project, merge, select tag for
root of target branch, select source branch), the "Syncronise view" pops up
and the diffs are not shown - what am I doing wrong.
Re: M7 Merge View??? [Learner driver] [message #216473 is a reply to message #215801] Fri, 26 March 2004 16:41 Go to previous messageGo to next message
Is there anything in the log file? Merging is run in the background so
you may not get prompted if there is an error (I can't remember the
behavior in M7).
> Thanks
Re: M7 Merge View??? [Learner driver] [message #216758 is a reply to message #215801] Sat, 27 March 2004 16:17 Go to previous message
Originally posted by: Hamelech.AlHakol.com
I ran into the same problem but after snooping around I discovered that the
Synchronize View toolbar allows you to select the contents displayed. One of
the items is the 'diffs' you just ran.
-David
"bigpig" <eguttridge@buildonline.com> wrote in message
news:c3v0l1$6q4$2@eclipse.org...
up
> Thanks
Previous Topic:MacOS X - No Java Perspective
Next Topic:Eclipse 3.0 M8 on linux amd 64
Current Time: Fri Jul 11 22:02:35 EDT 2025
Powered by FUDForum. Page generated in 0.46868 seconds
