Home » Language IDEs » Java Development Tools (JDT) » Java Project creation
Java Project creation [message #215792] Wed, 28 September 2005 07:07 Go to next message
Originally posted by: mom.mom.gmx.net
im writing a Plugin for a Java type Project. This means I need a Java
Project in the Workspace, but I also want to setup some things while
creation.
I found the JavaProjectWizard, but it is too much, I only need the First
page (JavaProjectWizardFirstPage). Is there a way to hide the second Page ?
Or better, how can I create a Java Project by myself ? Mean I create a
Wizard with the things really needed, and after the user clicked finish
I can call JDT to create the Project. I found JavaCore.create(IProject),
but I'm not sure from where to get the IProject Parameter?
thanks for help
regards Rainer
Re: Java Project creation [message #215854 is a reply to message #215792] Thu, 29 September 2005 05:39 Go to previous messageGo to next message
You can write your own wizard and add JavaProjectWizardFirstPage to
create the java project.
For creating project using code:
IProject myProject =
ResourcesPlugin.getWorkspace().getRoot().getProject("Project1 ");
myProject.create(null);
myProject.open(null);
IProjectDescription description = project.getDescription();
String[] natures = description.getNatureIds();
String[] newNatures = new String[natures.length+1];
System.arraycopy(natures, 0, newNatures, 0, natures.length);
newNatures[natures.length] = JavaCore.NATURE_ID;
description.setNatureIds(newNatures);
project.setDescription(description, null);
Rainer Weinhold wrote:
> creation.
> thanks for help
> regards Rainer
Re: Java Project creation [message #215882 is a reply to message #215854] Thu, 29 September 2005 10:09 Go to previous message
I testet your code, it works fine.
Except on little thing. (I guess the variable project was meant to be
called myProject.)
When running, it created the Project, and it creates a "bin" directory
within. But in this "bin" Directory there is a second .project file. It
happens in the myProject.setDescription(.... line.
This ist not very nice, but I can live with it. So I added a litte more
code :
IJavaProject javaProject=JavaCore.create(myProject);
JavaProject jp=(JavaProject)javaProject;
String str="/"+myProject.getName()+"/test";
jp.setOutputLocation( new Path(str),null);
The code works, it sets the output location in the Project, as long as I
didn't say ist schould be: ...+"/bin", then nothing happens and the
Output directory stays in the Project Folder.
Rainer
>> creation.
>> Page ?
>> thanks for help
>> regards Rainer
Previous Topic:refactor - move
Next Topic:Organize Import Action
Current Time: Sun Aug 31 01:25:25 EDT 2025
Powered by FUDForum. Page generated in 0.03582 seconds
