Home » Language IDEs » ServerTools (WTP) » Name jdbc is not bound in this Context
Name jdbc is not bound in this Context [message #215678] Wed, 18 June 2008 02:41 Go to next message
Originally posted by: frank.niedermann.ifm.com
we are migrating from WebSphere Developer Studio to Eclipse. I have
integrated Tomcat 5.5.26 as Server into Eclipse 3.2. If I start our
web projects in Tomcat out of Eclipse I get an exception:
I can think of two reasons for that:
1. We have configured our JDBC connections with JNDI in the server.xml
located in the Tomcat directory. Eclipse does not seem to read/know
that file.
2. While deploying the projects into Tomcat (without Eclipse) we use
a deployment descriptor which defines which data source to use from the
server.xml. Eclipse also does not know about that (how should it).
In WebSphere developer studio there were ways to configure JNDI and
JDBC for projects before running them on the server. How can I do
that within Eclipse and Tomcat?
Frank
Re: Name jdbc is not bound in this Context [message #215687 is a reply to message #215678] Wed, 18 June 2008 03:51 Go to previous messageGo to next message
Frank Niedermann wrote:
> Hello,
> that file.
Did you edit the file in your Tomcat installation directory or the
ServersX project in Eclipse?
Cheers
Philippe
Re: Name jdbc is not bound in this Context [message #215703 is a reply to message #215678] Wed, 18 June 2008 08:11 Go to previous messageGo to next message
we already solved this issue with the help of Rainer Jung
from KippData.
We had to add a context.xml into the META-INF directory of
our projects containing the data sources.
It's possible to add the data sources to the server.xml used
by Eclipse, it's located under Servers/Tomcat.
Frank
Re: Name jdbc is not bound in this Context [message #215937 is a reply to message #215703] Mon, 23 June 2008 13:16 Go to previous message
> from KippData.
> Frank
Yes, you can also modify the server.xml under the Servers project in
your workspace. The main disadvantage of this approach is that that
configuration will disappear if you remove the project from that server.
Putting it in META-INF/context.xml means the configuration is a
persistent part of the project.
Larry
Previous Topic:Server Status refresh?
Next Topic:Eclipse not finding classes.
Current Time: Sun Jul 27 07:19:09 EDT 2025
Powered by FUDForum. Page generated in 0.03768 seconds
