Home » Modeling » GMF (Graphical Modeling Framework) » Link Restriction
Link Restriction [message #215663] Fri, 16 January 2009 21:07 Go to next message
Hi All,
I need to add restrictions on my Link. I have the following problem:
http://img205.imageshack.us/my.php?image=modelhg6.jpg
A class with an element of the enum type that contains 4 EEnumLiteral
(Goal, Task, Resource and Softgoal). Desire to have a connection only
between the elements Goal and Task, ie Softgoal and Resource can not use
the link MeansEnd.
Help me!
Josias Paes
Re: Link Restriction [message #215702 is a reply to message #215663] Sat, 17 January 2009 05:40 Go to previous messageGo to next message
Originally posted by: jgreen.upb.de
Josias,
you can add an OCL Constraint to your link mapping. Set "language" to "ocl" and write your constraint expression into
the body. See http://wiki.eclipse.org/GMF_Tutorial_Part_2#Link_Constraints
Try something like
(self.source.type = 0 and self.target.type = 2) or (self.source.type = 2 and self.target.type = 0)
"self" refers to your MeansEnd element and I assume that your enum literal are numbered such that GOAL = 0 and TASK = 2.
Joel
Josias Paes wrote:
> Hi All,
> the link MeansEnd.
> Help me!
> Josias Paes
Re: Link Restriction [message #215754 is a reply to message #215702] Sat, 17 January 2009 10:59 Go to previous message
Thank you Joel,
I got the following:
Source end Constraint - self.type=ElementType::GOAL
Target end Constraint - self.type=ElementType::TASK
Its tip was valuable thanks!
Josias
Previous Topic:Notation package spec or doc ?
Next Topic:Compatment problem
Current Time: Fri Nov 07 04:08:49 EST 2025
Powered by FUDForum. Page generated in 0.06896 seconds
