Home » Archived » BIRT » Some Dependencies are not found
Some Dependencies are not found [message #215645] Wed, 31 January 2007 06:16 Go to next message
Originally posted by: dutt_partha.yahoo.co.in
In the Birt Wiki FAQ I found that the following jars and the folders are
needed to run the chart
Chart engine libraries:
* org.eclipse.birt.chart.device.extension_2.1.0.jar
* org.eclipse.birt.chart.device.svg_2.1.0.jar
* org.eclipse.birt.chart.device.swt_2.1.0.jar
* org.eclipse.birt.chart.engine.extension_2.1.0.jar
* org.eclipse.birt.chart.engine_2.1.0.jar
* org.eclipse.birt.chart.ui.extension_2.1.0.jar
* org.eclipse.birt.core.ui_2.1.0.jar
* org.eclipse.birt.core_2.1.0.jar
* Any jar from a custom extension plugin you wrote.
[edit]
Third party dependencies:
* org.mozilla.rhino_1.6.0 (folder)
* org.apache.commons.codec_1.3.0 (folder)
* org.apache.batik_1.6.0 (folder)
* org.apache.batik.pdf_1.6.0 (folder)
* org.apache.xerces_2.8.0 (folder)
* org.eclipse.emf.common_2.x.y.jar
* org.eclipse.emf.common.resources_2.x.y.jar
* org.eclipse.emf.ecore_2.x.y.jar
* org.eclipse.emf.ecore.resources_2.x.y.jar
* org.eclipse.emf.ecore.xmi_2.x.y.jar
But I can't find some of the jars
Form where I can get these.
Re: Some Dependencies are not found [message #215727 is a reply to message #215645] Wed, 31 January 2007 09:32 Go to previous message
Those can be found in the EMF project: www.eclipse.org/emf
David
> are needed to run the chart
> [edit]
> 80
Previous Topic:how display sql exception in birt viewer as in eclipse preview?
Next Topic:BIRT viewer
Current Time: Sat Jul 26 20:55:03 EDT 2025
Powered by FUDForum. Page generated in 0.04699 seconds
