Home » Eclipse Projects » Eclipse Platform » XML and Base64
XML and Base64 [message #215637] Thu, 25 March 2004 04:06
Originally posted by: xavier.omondo.com
I encode a binary stream with the commons-codec Base64 encoder from the Apache group.
The result string is stored in an attribute of an XML Element.
If I try to take a look in the Text Editor, I see nothing. The content seems to be missing.
This also apply If I use an XML Editor inside Eclipse.
However if I open this xml file with a standard text editor outside the platform
everything is fine.
Any Idea ?
I can send a sample upon request as I do not want to pollute this mailing list with
attached files.
Regards.
Previous Topic:How to pass -showsplash parameters through eclipse launcher program to Main clas
Next Topic:Validation in Properties Window
Current Time: Tue May 13 20:55:10 EDT 2025
Powered by FUDForum. Page generated in 0.03193 seconds
