Home » Eclipse Projects » Eclipse Platform » Code is done... now what?
Code is done... now what? [message #215613] Thu, 25 March 2004 03:44 Go to next message
Originally posted by: fayth69.cox.net
I must be totally and completely blind...
I am just learning java and swt. I am able to successfully compile and run
my programs from within the Eclipse environment. Now I would like to send
some of my programs to a friend to show him what I am doing. For the life of
me I cannot find one bit of documentation on what I need to include with the
..java file nor am I familiar with the exact command to use to run it. I've
now peeled my eyelids off for the last 4 hours trying to find documentation.
Could somebody please assist me? I'm so lost and frustrated at this point...
Thank you in advance... fayth
Re: Code is done... now what? [message #215795 is a reply to message #215613] Thu, 25 March 2004 10:54 Go to previous messageGo to next message
Originally posted by: mcorreia.linkz.com.br
You can create a jar package for your aplication.
Once you get the package, the command line is:
java -jar yourPackage.jar
remember that you need a Manifest referencing your Main-Class.
m.
Re: Code is done... now what? [message #215811 is a reply to message #215795] Thu, 25 March 2004 11:50 Go to previous messageGo to next message
Originally posted by: fayth.ut-mapdepot.com
Marcelo... thank you very much for your response. I receive errors when I
try to run this...
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/swt/widgets/Composite
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
I exported the jar like you said, made sure I generated the Manifest file
and selected the Main-Class entry-point. Do I need to export swt.jar too? Is
this a library issue or classpath issue?
Sincerely,
Fayth
"marcelo correia" <mcorreia@linkz.com.br> wrote in message
news:c3uv2b$4ar$1@eclipse.org...
> m.
run
send
life of
the
I've
documentation.
point...
Re: Code is done... now what? [message #215849 is a reply to message #215811] Thu, 25 March 2004 12:48 Go to previous messageGo to next message
Your application needs the swt library.
I believe you can pack it with your app, or put it into your classpath.
m.
> try to run this...
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> Sincerely,
> Fayth
>>m.
> run
> send
> life of
> the
> I've
> documentation.
> point...
Re: Code is done... now what? [message #215979 is a reply to message #215849] Thu, 25 March 2004 16:17 Go to previous messageGo to next message
I'm sorry Marcelo, I'm not getting any results. I've told Eclipse to pack
everything it can, I've installed swt.jar and the dll's in the \java\lib
\java\bin folders, I've tried a million variations of the java -classpath
and java -Djava.library.path= command line options. I still get the same
error as before.
Is there some documentation on how to do this? I can't believe this
documentation is not more easily accessible, I don't mean that in a bad
way - I'm just frustrated :P.
Sincerely, Fayth
news:c3v5p6$de4$1@eclipse.org...
> m.
I
> > try to run this...
file
too? Is
> > Sincerely,
> > Fayth
> >>m.
> > run
> > send
> > life of
with
> > the
> > I've
> > documentation.
> > point...
Re: Code is done... now what? [message #216005 is a reply to message #215979] Thu, 25 March 2004 17:46 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Have you created a plugin, or a java program? Are you using any eclipse
clases like SWT in your program, or is it pure java code?
> error as before.
> Sincerely, Fayth
>>m.
> I
>>>try to run this...
> file
> too? Is
>>>Sincerely,
>>> Fayth
>>>>m.
>>>run
>>>send
>>>life of
> with
>>>the
>>>I've
>>>documentation.
>>>point...
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Code is done... now what? [message #216047 is a reply to message #215979] Thu, 25 March 2004 18:33 Go to previous messageGo to next message
Have you tried to put swt.jar at: $JAVA_HOME:/jre/lib/ext ??
m.
> error as before.
> Sincerely, Fayth
>>m.
> I
>>>try to run this...
> file
> too? Is
>>>Sincerely,
>>> Fayth
>>>>m.
>>>run
>>>send
>>>life of
> with
>>>the
>>>I've
>>>documentation.
>>>point...
Re: Code is done... now what? [message #216114 is a reply to message #215979] Fri, 26 March 2004 00:26 Go to previous messageGo to next message
Gilbert and Marcelo... I finally figured out that the swt.jar goes in the
\lib\ext folder, I was correct in putting the dll in the \bin folder. Next I
needed -Djava.library.path=<thepath to \lib\ext> in my command line when I
ran my demo. :)
Thank you both, especially Marcelo, for answering me. I'm on my way!!!!
Sincerely, Fayth
"Fayth" <fayth@ut-mapdepot.com> wrote in message
news:c3vi02$sfj$1@eclipse.org...
> error as before.
> Sincerely, Fayth
> > m.
when
> I
> > > try to run this...
> file
> too? Is
> > > Sincerely,
> > > Fayth
> > >>m.
and
> > > run
> > > send
> > > life of
> with
> > > the
> > > I've
> > > documentation.
> > > point...
Re: Code is done... now what? [message #216222 is a reply to message #216114] Fri, 26 March 2004 08:34 Go to previous messageGo to next message
Cheers
m.
> ran my demo. :)
> Sincerely, Fayth
>>error as before.
>>Sincerely, Fayth
>>>m.
> when
>>I
>>>>try to run this...
>>file
>>too? Is
>>>>Sincerely,
>>>> Fayth
>>>>>m.
> and
>>>>run
>>>>send
>>>>life of
>>with
>>>>the
>>>>I've
>>>>documentation.
>>>>point...
Re: Code is done... now what? [message #216295 is a reply to message #216114] Fri, 26 March 2004 09:58 Go to previous messageGo to next message
> ran my demo. :)
That is odd. Seems like you put the file in the *wrong* \lib\ext
folder. Since you have the JDK, you have two \lib\ext folders. This
folder is loaded automatically by the JRE. So you should not need that
-D line. use that line if you put the jar in your own location
somewhere, which is best anyway because it probably slows the loading fo
the jvm a bit.
you have a \lib\ext folder probably in c:/jdk/jre/lib/ext and another in
c:/program files/java/jre/lib/ext
make sure the java.exe you are running corresponds to the ext folder you
put the swt in.
> Sincerely, Fayth
>>error as before.
>>Sincerely, Fayth
>>>m.
> when
>>I
>>>>try to run this...
>>file
>>too? Is
>>>>Sincerely,
>>>> Fayth
>>>>>m.
> and
>>>>run
>>>>send
>>>>life of
>>with
>>>>the
>>>>I've
>>>>documentation.
>>>>point...
Respectfully,
CL Gilbert
Re: Code is done... now what? [message #216316 is a reply to message #216295] Fri, 26 March 2004 10:50 Go to previous messageGo to next message
So you're saying it SHOULD go in the \j2re.1.4_03\jre\lib\etc??? What
happens when I distribute it to, say, people who only have the java Virtual
Machine installed (11MB versus 136MB)?
Fayth
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:c41g6c$u3u$1@eclipse.org...
the
Next I
I
> > ran my demo. :)
> the jvm a bit.
> put the swt in.
> > Sincerely, Fayth
pack
java -classpath
> >>error as before.
> >>Sincerely, Fayth
> >>>m.
> > when
> >>I
> >>>>try to run this...
> >>file
> >>too? Is
> >>>>Sincerely,
> >>>> Fayth
> >>>>>m.
> > and
> >>>>run
> >>>>send
> >>>>life of
> >>with
> >>>>the
it.
> >>>>I've
> >>>>documentation.
> >>>>point...
> Respectfully,
> CL Gilbert
Re: Code is done... now what? [message #216364 is a reply to message #216316] Fri, 26 March 2004 12:21 Go to previous messageGo to next message
They need the jre(around 10mb). You can put swt.jar on it.
I think thats all you need.
cheers
m.
> Fayth
> the
> Next I
> I
>>>ran my demo. :)
>>the jvm a bit.
>>put the swt in.
>>>Sincerely, Fayth
> pack
> java -classpath
>>>>error as before.
>>>>Sincerely, Fayth
>>>>>m.
>>>when
>>>>I
>>>>>>try to run this...
>>>>file
>>>>too? Is
>>>>>>Sincerely,
>>>>>> Fayth
>>>>>>>m.
>>>and
>>>>>>run
>>>>>>send
>>>>>>life of
>>>>with
>>>>>>the
> it.
>>>>>>I've
>>>>>>documentation.
>>>>>>point...
>>Respectfully,
>>CL Gilbert
Re: Code is done... now what? [message #216413 is a reply to message #216364] Fri, 26 March 2004 15:01 Go to previous message
Cool ... thanks for all the assistance guys!!! Very much appreciated!
Fayth
news:c41ohp$9uf$1@eclipse.org...
> cheers
> m.
Virtual
> > Fayth
message
> > the
> > Next I
when
> > I
> >>>ran my demo. :)
> >>the jvm a bit.
> >>put the swt in.
> >>>Sincerely, Fayth
> > pack
\java\lib
> > java -classpath
same
> >>>>error as before.
bad
> >>>>Sincerely, Fayth
classpath.
> >>>>>m.
> >>>when
> >>>>I
> >>>>>>try to run this...
Source)
> >>>>file
> >>>>too? Is
> >>>>>>Sincerely,
> >>>>>> Fayth
> >>>>>>>m.
> >>>and
> >>>>>>run
to
> >>>>>>send
the
> >>>>>>life of
include
> >>>>with
> >>>>>>the
> > it.
> >>>>>>I've
> >>>>>>documentation.
this
> >>>>>>point...
> >>Respectfully,
> >>CL Gilbert
Previous Topic:PluginClassLoader
Next Topic:RCP main site?
Current Time: Thu Jul 17 01:55:44 EDT 2025
Powered by FUDForum. Page generated in 0.05060 seconds
