| Unable to use night build [message #20913] | Sun, 18 May 2008 10:55  |  |
| Eclipse User  |  |  |  |  | Originally posted by: fab.spinelli.gmail.com
 Hi all. I'm an italian student trying to port an existing project based on
 Eclipse plugins onto mobile devices.
 I've founded the MTJ project and downloaded the N20080430 nightly build.
 I've installed a fresh Eclipse 3.3.2 and succesfully installed the MTJ
 runtime plugins and future, but when I try to create a new "Midlet
 Project" or "Java ME Midlet" I obtain the following error messages:
 1) trying to create new "Midlet Project" ---> Plugin org.eclipse.mtj.ui
 was unable ti load class
 org.eclipse.mtj.ui.internal.wizards.NewJ2MEProjectWizard
 2) trying to create new "Java ME Midlet" ---> Plugin org.eclipse.mtj.ui
 org.eclipse.mtj.ui.internal.wizards.NewMidletWizard.
 It seems that some classes are not present in the downloaded plugin and
 futures.
 It's a strange thing, and the two error messages seems to be "switched".
 I'm also experience some trouble trying to configure preferences. If I
 open the menu Windows-->Preferences and select any of the "Mobile Tools
 for Java" preferences page I alway get this error message "Unable to
 create the selected preference page.Reason :
 org/eclipse/mtj/ui/internal/preferences/xxxPage (Unsupported major.minor
 version 49.0)" where xxx is the name of the preference page I'm trying to
 select.
 I know this kind of error is related to installed and used JRE, but I'm
 using Java 6 Update 6 Sdk and properly configured preferences for compiler
 (don't know if this can help).
 What's my error? Do I need to download something else? I extracted the
 jar plugins and I can't find org.eclipse.mtj.ui.internal package...
 Any suggest will be very appreciate, thank you so much.
 (Please, sorry for my poor English :) )
| Re: Unable to use night build [message #20925 is a reply to message #20919] | Mon, 19 May 2008 14:02  |  |
 Hi MTJ guys. I've "resolved" my problem. Thanks for reading naive
 questions and sorry for wasting your time. As i supposed it was a
 problem with JRE, as mentioned I've installed JDK 6 Update 6 on my
 system, but Eclipse continued to start with JRE 1.4! Simply add -vm
 switch pointing to correct JRE path in eclipse.ini resolved the problem.
 I'll open a new thread for a new ( also naive :) ) question.
 Spinelli Fabrizio ha scritto:
 > Sorry for mistake.I still obtain this error messages, but I've founded
 > packeage org.eclipse.mtj.ui.internal in plugin jar! And I founded the
 > NewJ2MEProjectWizard.class and
 > NewMidletWizard.class... I don't understand.
 > Fabrizio
 >> based on Eclipse plugins onto mobile devices.
 >> build. I've installed a fresh Eclipse 3.3.2 and succesfully installed
 >> the MTJ runtime plugins and future, but when I try to create a new
 >> "Midlet Project" or "Java ME Midlet" I obtain the following error
 >> messages:
 >> org.eclipse.mtj.ui was unable ti load class
 >> and futures.
 >> I open the menu Windows-->Preferences and select any of the "Mobile
 >> Tools for Java" preferences page I alway get this error message
 >> "Unable to create the selected preference page.Reason :
 >> major.minor version 49.0)" where xxx is the name of the preference
 >> page I'm trying to select.
 >> I'm using Java 6 Update 6 Sdk and properly configured preferences for
 >> compiler (don't know if this can help).
 >> the jar plugins and I can't find org.eclipse.mtj.ui.internal package...
| Re: Unable to use night build [message #566981 is a reply to message #20913] | Sun, 18 May 2008 11:21  |  |
 Fabrizio
 > messages:
 > and futures.
| Re: Unable to use night build [message #567010 is a reply to message #20919] | Mon, 19 May 2008 14:02  |  |
 > Fabrizio
 >> messages:
 >> and futures.
FUDForum. Page generated in 0.03856 seconds
