Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » tcl debugging with dltk
tcl debugging with dltk [message #20867] Tue, 04 March 2008 16:34 Go to next message
hi,
i happened across the DLTK plugins a few days ago and am thrilled at the
prospect of tcl debugging support in eclipse. i downloaded the 0.9.2
version of DLTK and am trying to configure tcl debugging. i couldn’t find
any documentation on how to do this, but based on this post -
http://dev.eclipse.org/mhonarc/lists/dltk-dev/msg00035.html - gathered
that i need to install a tcl debugging engine separately from the DLTK
install in order to debug a tcl app. is that correct?
i downloaded a 21 day trial of ActiveState’s Tcl Dev Kit but don’t see a
file named dbgp_tcldebug.exe, which the aforementioned post identified as
the debugger to use with DLTK. selecting C:\TclDevKit\bin\tcldebugger.exe
didn’t work.
which tcl debugger engines has DLTK been tested with, and what are the
associated debugging engines to use with DLTK? is there any documentation
i missed on how to set this up?
thanks.
-mike
Re: tcl debugging with dltk [message #20885 is a reply to message #20867] Thu, 06 March 2008 02:51 Go to previous messageGo to next message
Hi Michael,
Please use this link
http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebu gging
Dmitriy
Michael Grove wrote:
> hi,
> version of DLTK and am trying to configure tcl debugging. i couldn�t
> find any documentation on how to do this, but based on this post -
> i downloaded a 21 day trial of ActiveState�s Tcl Dev Kit but don�t see a
> as the debugger to use with DLTK. selecting
> C:\TclDevKit\bin\tcldebugger.exe didn�t work.
> documentation i missed on how to set this up?
> thanks.
> -mike
Re: tcl debugging with dltk [message #21694 is a reply to message #20885] Thu, 13 March 2008 08:39 Go to previous messageGo to next message
thanks, that worked great. i did notice that with that debugger i'm not
able to introspect lists or arrays in the Variables view. is that a
limitation of the debugger or the DLTK plugins?
Re: tcl debugging with dltk [message #21739 is a reply to message #21694] Thu, 13 March 2008 08:55 Go to previous messageGo to next message
Hi Michael,
Arrays and list are supported.
Could you please create a bug report with screenshot in Eclipse bug tracker for DLTK project.
Andrei Sobolev.
Re: tcl debugging with dltk [message #21784 is a reply to message #21739] Thu, 13 March 2008 09:35 Go to previous message
submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=222564, thanks. i
found it wasn't a general list/array problem, any variable name beginning
with 'args' will not display in the Variables view.
Previous Topic:Accessing a Java Plugin from DLTK
Next Topic:Signature change for IBuildpathContainer.getBuildpathEntries()
Current Time: Sun Nov 23 03:13:08 EST 2025
Powered by FUDForum. Page generated in 0.08776 seconds
