Home » Newcomers » Newcomers » Using Eclipse AST Parser
Using Eclipse AST Parser [message #215017] Mon, 11 June 2007 08:03
Originally posted by: nitrousfiz.googlemail.com
I need to write a (parser) program that will behave in the following way -
Input - some line number
Processing - identify all variable names in that line & find line numbers of
the declarations of the identified variables
Output - line numbers of the declarations of the identified variables
Example: Suppose you are given the following Java program -
1. public class HelloWorld {
2. public static void main(String[] args) {
3. int a;
4. int b;
5. int c;
6. a=1;
7. b=2;
8. c=3;
9. a=a+c;
10. }
11. }
Input: Line 9
Processing:
* Identify variables in line 9 - variables a and c
* Find declaration line number of variable a & c - Lines 3 and 5
* Output these line numbers
Output: Lines 3, 5
I was told that this is possible by using the Eclipse AST Parser.
Please advice how can I start solving this problem using it and what code to
put inside which method(s) in the AST explorer/traverser?
Thanks for your help.
Fayezin
Previous Topic:Creating popup menu actions during runtime
Next Topic:Question about the Problems view
Current Time: Sun Aug 31 23:58:01 EDT 2025
Powered by FUDForum. Page generated in 0.10533 seconds
