| Problem with running eclipse 3 [message #20855] |
Mon, 31 January 2005 08:41  |
Originally posted by: Lukasz.Nowak.eu.org
Hello everyone,
That's my envrioment:
SuSE 9.2 on AMD 64
java-1_4_2-sun-1.4.2.06-1.1
eclipse-jdt-3.0-5.1
eclipse-platform-3.0-5.1
eclipse-source-3.0-5.1
eclipse-scripts-3.0-5.1
eclipse-pde-3.0-5.1
eclipse-gtk2-3.0-5.1
eclipse-3.0-5.1
All packages are SuSE standard. My Eclipse won't run - after splash screen
it gives my message box with log. Log is avaiable here:
http://bajtek.ankom.net/~shufla/1107178235738.log
What could be the problem? Eclipse install from Eclipse site, not SuSE
powered do not run either.
Thanks in advance,
Lukasz Nowak
| Re: Problem with running eclipse 3 [message #21937 is a reply to message #21481] |
Tue, 01 February 2005 01:39  |
Jeff Myers wrote:
> Are you running 64 bit linux? If so, are you using Sun's 64 bit linux
> JRE? (most likely not, because I believe that they've only released a
> Java 1.5 version) And finally, are you running the 64 bit version of
> Eclipse?
You are right. Right now I'm using official Java 1.5-64 & Eclipse-GTK2-64 -
all runs fine.
I'm just shocked, that packages from SuSE do not work anymore (it has been
working few days ago on same machine! - maybe some updates damaged it).
Thank you for your help,
Lukasz
FUDForum. Page generated in 0.08648 seconds
