| Build a standalone SWT Application [message #20842] |
Mon, 31 January 2005 02:58  |
Originally posted by: antoi.darti.tiscali.fr
Hello i installed Eclipse 3.O.1
i am trying the tutorial "Hello World" for SWT standalone appli
After adding the external swt.jar libraries, as said in the tutorial,
I create a class HelloWorld main,
when I copy paste ;in the main :
Display display = new Display ();
Shell shell = new Shell (display);
Label label = new Label (shell, SWT.CENTER);
the three types are not recognized ?
Display cannot be resolved or is not a type
Is it because I have to add in the path where are the swt libraries ?
Thank you for help
Antoine
| Re: Build a standalone SWT Application [message #25762 is a reply to message #20842] |
Sat, 05 February 2005 18:15  |
> Thank you for help
> Antoine
If you have already added swt.jar to Java Build Path you will need to
import the needed classes to the project, ctrl+shift+o will do it for
you, if asked choose the swt ones, no the awt.
FUDForum. Page generated in 0.28935 seconds
