Home » Newcomers » Newcomers » Working from another computer
Working from another computer [message #214746] Sat, 09 June 2007 13:23 Go to next message
Originally posted by: galadegaffes.gmail.com
I'd like to simply copy my project directory to another computer (a Windows
PC), work on it and copy them back to my Macintosh. I can't seem to do it
though. How do I go about working on a project on different computers. Is
CVS my only option? Complicated for nothing?
Alex
Re: Working from another computer [message #214753 is a reply to message #214746] Sat, 09 June 2007 13:44 Go to previous messageGo to next message
Originally posted by: news.pellaton.li
Copying the workspace is not a good idea - especially not between
operating systems that use different line endings and so. We encountered
several issues whilst copying workspaces (esp. between smb-drives and
local ntfs drives).
Sharing your projects on a CVS server is one possibility and the Eclipse
import/export function a second one.
I'd go for version control, because you get an easy way to synchronize
your different workspaces; you get revision control including the
possibility to tag or roll back easily...
Michael
Re: Working from another computer [message #215120 is a reply to message #214746] Mon, 11 June 2007 23:29 Go to previous messageGo to next message
Don't forget to consider subversion to manage your source code. It maybe a
better solution for you than using CVS.
David
"Galadegaffes" <galadegaffes@gmail.com> wrote in message
news:f4ennj$vpr$1@build.eclipse.org...
> Windows PC), work on it and copy them back to my Macintosh. I can't seem
> to do it though. How do I go about working on a project on different
> computers. Is CVS my only option? Complicated for nothing?
> Alex
Re: Working from another computer [message #215484 is a reply to message #214746] Wed, 13 June 2007 09:31 Go to previous message
As others have said, CVS or Subversion is really the best option.
Neither one is really complicated. But if you want the "poor man's"
answer, File>Export projects from one Eclipse to an Archive (ZIP) file,
then File >Import them into the other Eclipse.
Hope this helps,
Eric
Previous Topic:workspace\project structure
Next Topic:query a String to the Help>Search Dialog
Current Time: Thu Jul 17 20:35:18 EDT 2025
Powered by FUDForum. Page generated in 0.09062 seconds
