"Build (if required) before launching" changes active build configuration [message #214615] |
Mon, 21 April 2008 08:22 |
Originally posted by: lukester_null.yahoo.co.uk
With a standard makefile project, I find that having the "Build (if
required) before launching" setting enabled changes the active build
configuration when running or debugging.
My project has two configurations - mdid (old style boost naming,
essentially debug with dynamic libraries) and mdi (release).
The makefile generates two different binaries for each config, but also
a soft link with a common name (the project's name) pointing to the last
built binary. (It seems like variables from the build config can't be
used in the run config so that's why I do this to create a "common" name
that can be used across run configurations).
So, starting with no run configurations defined:
1. Select mdid as active build configuration
2. Build
3. Run - select the soft link. All is well.
4. Now select mdi as the build configuration
5. Run - builds mdid build again and runs that. Active build
configuration is now mdid.
I think someone else may have tripped over this:
http://dev.eclipse.org/newslists/news.eclipse.tools.cdt/msg1 5072.html or
are we going crazy?!
My work around for now is to disable "Build (if required) before
launching" and do a two stage build then debug/run, rather than just
debug/run but it would be nice if it's possible to stop it from changing
the build configuration...
Is this intentional behavior or is there some other way to "tie
together" a build and run configuration? Or in fact, decouple them as it
seems the run configuration created in step 3 is somehow tied to the
build configuration active at the time!
Tried both Fedora 8's CDT (4.0.1) and latest from eclipse.org.
Thanks in advance for any help.
Luke Elliott.
FUDForum. Page generated in 0.21442 seconds
