Home » Language IDEs » ServerTools (WTP) » Changing "“Always use this server..." option
Changing "“Always use this server..." option [message #213945] Fri, 16 May 2008 09:50 Go to next message
The project I'm working on creates our own custom projects that use some
of the WTP facets and the Run on server features. I've noticed that on
"ordinary" dynamic web projects, there is a property section, Server,
where the user can change his mind if he once checked the "“Always use
this server..." option when launching his app.
For some reason, our projects don't have that properties section and our
users don't have a way to change the setting once they check the box.
I have 2 questions:
1) Is there a straightforward way to get that section included on our
project properties? Is it tied to the "Dynamic Web Module" facet? If so,
is there any other option (our projects have their own web deployment
facet that conflicts with "Dynamic Web Module")?
2) Where is the setting stored so that I can offer a work-around way to
clear it and get the user back to where they are prompted to select the
server again?
TIA,
Eric
Re: Changing "“Always use this server..." option [message #214594 is a reply to message #213945] Fri, 30 May 2008 10:16 Go to previous messageGo to next message
Bump - any ideas? Should this go to the dev mailing list instead?
> I have 2 questions:
> server again?
> TIA,
> Eric
Re: Changing "“Always use this server..." option [message #214600 is a reply to message #214594] Fri, 30 May 2008 11:09 Go to previous message
>> some of the WTP facets and the Run on server features. I've noticed
>> that on "ordinary" dynamic web projects, there is a property section,
>> Server, where the user can change his mind if he once checked the
>> "“Always use this server..." option when launching his app.
>> our users don't have a way to change the setting once they check the box.
>> I have 2 questions:
>> so, is there any other option (our projects have their own web
>> deployment facet that conflicts with "Dynamic Web Module")?
>> to clear it and get the user back to where they are prompted to select
>> the server again?
>> TIA,
>> Eric
For #2, WTP server related "info" often ends up under
".metadata\.plugins\org.eclipse.wst.server.core". This setting appears
to go in the modules.xml file.
Larry
Previous Topic:Web project does not start
Next Topic:Axis2 code generation dialog borked!
Current Time: Sun Aug 31 14:25:02 EDT 2025
Powered by FUDForum. Page generated in 0.51347 seconds
