Home » Language IDEs » ServerTools (WTP) » Renaming a project does not update org.eclipse.wst.common.component
Renaming a project does not update org.eclipse.wst.common.component [message #213930] Fri, 16 May 2008 04:55 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello!
Is it a known bug (maybe already fixed?) that when you rename a project
the deploy-name attribute of wb-module element in
org.eclipse.wst.common.component file is not updated with the new name?
Or should I file a new bug?
By not updating that value, if you copy and paste a dynamic web project
in order to duplicate it, you'll find more than one web module with the
same name, and this is confusing when you work with servers, J2EE
modules, etc..
Mauro.
Re: Renaming a project does not update org.eclipse.wst.common.component [message #213940 is a reply to message #213930] Fri, 16 May 2008 04:56 Go to previous message
I forgot to say I'm working with WTP 2.0.2.
Mauro.
Previous Topic:reuse the project facets framework for other wizards
Next Topic:Alternate way of packaging projects for deployment
Current Time: Sat Nov 08 21:14:52 EST 2025
Powered by FUDForum. Page generated in 0.03420 seconds
