Home » Archived » Visual Editor (VE) » Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2
Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #20743] Thu, 26 February 2004 07:26 Go to next message
We have a plug-in for WSAD 5.0.1 (and Visual Editor) which we would like
to port to Eclipse 2.1.2 and VE 0.5.0.
Is there any documentation about the migration path one needs to take?
Will the subsequent port to Eclipse 3.0 and VE 1.0 be a big step?
- Janak
janak.mulani@canoo.com
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #20824 is a reply to message #20743] Thu, 26 February 2004 12:57 Go to previous messageGo to next message
Janak,
I've just posted such a migration path in the previous thread "Adding new
Beans to the Palette"
Tell me if it's what you're looking for.
Regarding Eclipse 3.0 and VE 1.0 I think you could have a look at the plugin
files to see how deeply they changed (that's what I'm going to do anyway,
I'll keep you posted)
Sebastien.
"janak" <janak.mulani@canoo.com> wrote in message
news:c1komh$no8$1@eclipse.org...
> Thanks
> - Janak
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #21331 is a reply to message #20824] Fri, 27 February 2004 05:15 Go to previous messageGo to next message
Sebastien,
Many thanks.
Actually just after doing yesterday's post I set about changing Joe's
palette example for Eclipse 2.1.2. And I made all the changes (to xml and
xmi) that you have listed in your solution.
I ran Joe's example palette in WSAD 5.0.1 and it ran fine.
I then ran the "changed for Eclipse example palette" but it does not run
because it is not able to find the Bean Jars (even after setting the
variable). It seems the Classpath specification has changed between WSAD
5.0.1 and Eclipse 2.1.2. To make the Eclipse example run I had to
explicitly include the bean jars in the build path.
Have you experienced this?
(I am taking the liberty to send my Eclipse plug-in to you for
verification, pl install and run it if you have time.)
Sure this helps and as said earlier I did the same after posting my query.
But it takes lot of groping around and ends up in taking a path that
perhaps others have already taken.
So it would help a lot if:
1. There is a global picture of what all needs to change.
2. And info about the semantics of change and specifics where possible.
Thanks.
Actually what I meant was is it a good idea to go to Eclipse 2.1.2 and VE
0.5.0 from WSAD 5.0.1 or should we go to Eclipse 3.0 and VE 1.0.0?
- Janak
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #21339 is a reply to message #21331] Fri, 27 February 2004 08:52 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
You can go to 0.5.0 and from there to the current 1.0.0. The override
files are the same format at this time for 0.5.0 and 1.0.0, however, in
the next few weeks we are stepping up to the EMF Opensource version of
the override files (from our private internal version), which is a
different format. However, since we have to do the conversion ourselves
of our many files, I'm going to see about writing a conversion utility
to convert the 1.0.0 current format to the new format. And I'll put this
utility out on the VEP site when ready.
Thanks, Rich Kulp
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #21460 is a reply to message #20824] Thu, 26 February 2004 13:23 Go to previous messageGo to next message
Ok I've just looked at the plugin files :
- Few differences in plugin manifest files (just more required plugins)
- No differences in the palette XMI files
So I assume the palette plugins for VE 0.5.0 will work like a charm with VE
1.0.0
Anybody in the VE team could confirm it ?
"S
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #21482 is a reply to message #21331] Mon, 01 March 2004 04:12 Go to previous message
Janak,
I've ran your plugin and it works fine for me (no classpath problem, and no
need to add the jars manually, the variable does the job)
The only problem you could have is if you installed the VE Examples plugin
(it contains the wizzowidget example) so there would be 2 WIZZO_WIDGETS
variable and it does not work very well (actually you could not use the
variable at all).
So I renamed the variable to WIZZO_WIDGETS_PORT in your plugin definition
and it works fine.
The XMI looks good to me.
I send you the modified plugin.xml file (you don't need it if you haven't
installed VE Examples).
Hope that helps,
Sebastien.
news:c1n5b8$nae$1@eclipse.org...
> Sebastien,
> Many thanks.
plugin
anyway,
> Thanks.
> - Janak
  • Attachment: plugin.xml
    (Size: 1.67KB, Downloaded 178 times)
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #582537 is a reply to message #20743] Thu, 26 February 2004 12:57 Go to previous message
Janak,
Sebastien.
> Thanks
> - Janak
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #582649 is a reply to message #20824] Fri, 27 February 2004 05:15 Go to previous message
Sebastien,
Many thanks.
Thanks.
- Janak
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #582668 is a reply to message #21331] Fri, 27 February 2004 08:52 Go to previous message
Thanks, Rich Kulp
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #582908 is a reply to message #20824] Thu, 26 February 2004 13:23 Go to previous message
1.0.0
"S
Re: Migration of plug-in from WSAD 5.0.1 to Eclipse 2.1.2 [message #582919 is a reply to message #21331] Mon, 01 March 2004 04:12 Go to previous message
Janak,
variable at all).
and it works fine.
Hope that helps,
Sebastien.
> Sebastien,
> Many thanks.
plugin
anyway,
> Thanks.
> - Janak
    (Size: 1.67KB, Downloaded 137 times)
Previous Topic:M6 version
Next Topic:VE does not install
Current Time: Sat Nov 08 00:30:27 EST 2025
Powered by FUDForum. Page generated in 0.05261 seconds
