Home » Language IDEs » ServerTools (WTP) » Problems with WTP Tutorial - Creating Bottom Up Web Service
Problems with WTP Tutorial - Creating Bottom Up Web Service [message #213823] Wed, 14 May 2008 09:43 Go to next message
Hi all,
I followed exactly the instructions of the tutorial "Creating Bottom Up
Web Service via Apache Axis2". Everything worked fine until I tried to
deploy the web service to Tomcat. The error on the tomcat console says:
java.lang.NoClassDefFoundError: javax/xml/stream/XMLStreamException
org.apache.axis2.transport.http.AxisServlet.initConfigContex t(AxisServlet.java:511)
at org.apache.axis2.transport.http.AxisServlet.init(AxisServlet .java:431)
org.apache.axis2.transport.http.AxisAdminServlet.init(AxisAd minServlet.java:55)
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1161)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:981)
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:4045)
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4351)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:566 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Also in Eclipse the import of javax.xml.stream.XMLOutputFactory and
javax.xml.stream.XMLStreamException in HappyAxis.jsp can't be resolved.
I'm working with Eclipse 3.3.2, the latest WTP, Tomcat 6.0.14 and Axis2
1.4. Can anyone help me?
Bye - Reinhold.
Re: Problems with WTP Tutorial - Creating Bottom Up Web Service [message #213840 is a reply to message #213823] Wed, 14 May 2008 10:39 Go to previous messageGo to next message
This error suggests that the stax-api jar is missing. It should be part
of the Axis2 runtime specified in your Axis2 Preferences and it should
have been copied to the WEB-INF/lib of your project when it was created
in the tutorial.
Larry
Reinhold Bentele wrote:
> Hi all,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Bye - Reinhold.
Re: Problems with WTP Tutorial - Creating Bottom Up Web Service [message #214740 is a reply to message #213823] Mon, 02 June 2008 14:34 Go to previous messageGo to next message
Originally posted by: rdargent.gmail.com
Hi Reinhold,
Have you solved your problem?
I am facing the same problem and I am still looking for a solution.
Re: Problems with WTP Tutorial - Creating Bottom Up Web Service [message #218164 is a reply to message #214740] Thu, 24 July 2008 11:45 Go to previous message
Originally posted by: carla.bolognesi.gmail.com
I'm also working with Eclipse 3.3.2, the latest WTP, Tomcat 6.0.14, Axis2
1.4, Java 5 and I get the same error.
I did find the jar containing the missing class in the axis lib folder and
I copied it down into the project lib folder manually. This means all the
jsps compile correctly, but when I deploy I still get no joy.
Did either of you solve the problem?
also, do you know if the webtools can be used with tomcat 5 and java 1.4
thanks
Carla
Previous Topic:Buggy 'New Web Project' dialogue
Next Topic:404 /soap/servlet/rpcrouter when run web services explorer in Eclipse
Current Time: Wed Nov 05 01:23:43 EST 2025
Powered by FUDForum. Page generated in 0.06286 seconds
