Home » Language IDEs » Java Development Tools (JDT) » Unable to locate matching org.apache.xerces plugin.
Unable to locate matching org.apache.xerces plugin. [message #1733] Tue, 22 April 2003 05:42 Go to next message
Originally posted by: ajayinfo.yahoo.com
Hi All,
i just transferred my code from Eclipse 1.0 to Eclipse 2.0 and everything
broke.. most of it was because of the classpath problem. I have managed to
fix everything and now it compiles (atlast). During runtime i get the
following error
java.lang.RuntimeException: Fatal Error: Unable to locate matching
org.eclipse.core.internal.boot.PlatformConfiguration.locateD efaultPlugins(PlatformConfiguration.java:2223).............. ..............................................
I really dont understand why. Is this because of some ambiguity in my
classpath. i saw a similar post and that person had posted that there was
some problem with his classpath but didnt mention as to wat the problem
was.
My classpath looks like this:
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry kind="var"
path=" ECLIPSE_HOME/plugins/org.eclipse.core.runtime_2.0.1/runtime. jar "
sourcepath=" _ORG_ECLIPSE_PLATFORM_SOURCE/org.eclipse.core.runtime_2.0.1/ runtimesrc.zip "/>
path="ECLIPSE_HOME/plugins/org.eclipse.core.boot_2.0.1/boot.jar "
sourcepath=" _ORG_ECLIPSE_PLATFORM_SOURCE/org.eclipse.core.boot_2.0.1/boo tsrc.zip "/>
<classpathentry kind="var" path="JRE_LIB" rootpath="JRE_SRCROOT"
sourcepath="JRE_SRC"/>
<classpathentry kind="lib" path="ibmjsse.jar"/>
path="ECLIPSE_HOME/plugins/org.eclipse.search_2.0.1/search.jar "/>
path="ECLIPSE_HOME/plugins/org.eclipse.ui_2.0.1/workbench.jar "
sourcepath=" _ORG_ECLIPSE_PLATFORM_SOURCE/org.eclipse.ui_2.0.1/workbenchs rc.zip "/>
path=" ECLIPSE_HOME/plugins/org.eclipse.swt.win32_2.0.1/ws/win32/sw t.jar "
sourcepath=" _ORG_ECLIPSE_PLATFORM_WIN32_SOURCE/org.eclipse.swt.win32_2.0 .1/ws/win32/swtsrc.zip "/>
path=" ECLIPSE_HOME/plugins/org.eclipse.core.resources_2.0.1/resour ces.jar "
sourcepath=" _ORG_ECLIPSE_PLATFORM_SOURCE/org.eclipse.core.resources_2.0. 1/resourcessrc.zip "/>
path="ECLIPSE_HOME/plugins/org.eclipse.jdt.core_2.0.1/jdtcore.jar "/>
path="ECLIPSE_HOME/plugins/org.apache.xerces_4.0.5/xercesImpl.jar "/>
path=" ECLIPSE_HOME/plugins/org.apache.xerces_4.0.5/xmlParserAPIs.j ar "/>
<classpathentry kind="output" path="bin"/>
</classpath>
Re: Unable to locate matching org.apache.xerces plugin. [message #1762 is a reply to message #1733] Tue, 22 April 2003 09:14 Go to previous messageGo to next message
I believe that the xerces plugin is version 4.0.7 (at least that is what it
is in 2.1). I would check the xerces plugin version.
You should just make the jump to 2.1
HTH
Darins
"Ajay" <ajayinfo@yahoo.com> wrote in message
news:b832ps$rls$1@rogue.oti.com...
> Hi All,
> following error
> at
atformConfiguration.java:2223).............................. ................
> was.
> <classpath>
imesrc.zip"/>
..zip"/>
ip"/>
s/win32/swtsrc.zip"/>
sourcessrc.zip"/>
> </classpath>
Re: Unable to locate matching org.apache.xerces plugin. [message #2195 is a reply to message #1762] Wed, 23 April 2003 02:09 Go to previous message
Well im using Websphere Studio Application Developer v 5.0 which has
support for Eclipse 2.0 only. Is there any way i cant go ahead with the
existing Eclipse and reslove this problem.
thanx
Ajay
> HTH
> Darins
> > Hi All,
> > following error
> > at
> > was.
> > <?xml version="1.0" encoding="UTF-8"?>
> > <classpath>
> imesrc.zip"/>
> ..zip"/>
> ip"/>
> sourcessrc.zip"/>
> > </classpath>
Previous Topic:Classpath of a plugin programmitically ?
Next Topic:Rebuild Project
Current Time: Sun Jul 13 10:25:39 EDT 2025
Powered by FUDForum. Page generated in 0.24238 seconds
