Home » Eclipse Projects » Eclipse Platform » Proper way of logging from plugin
Proper way of logging from plugin [message #213575] Fri, 19 March 2004 11:28 Go to next message
Hi all,
I generaly use log4j or java logging api,
I don't want to add the log4j jar nor restrict to j1.4
Does eclipse have a defined method for logging (errors and debug)?
Thanks for any help
It's a vast world the eclipse api...
Re: Proper way of logging from plugin [message #213845 is a reply to message #213575] Fri, 19 March 2004 21:31 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
Plugin.getLog()
Pascal
Miguel Griffa wrote:
> Hi all,
> Thanks for any help
Re: Proper way of logging from plugin [message #213934 is a reply to message #213575] Sat, 20 March 2004 03:09 Go to previous messageGo to next message
In addition for debugging see the ".options" file.
Cu, Gunnar
Re: Proper way of logging from plugin [message #214864 is a reply to message #213934] Tue, 23 March 2004 08:55 Go to previous messageGo to next message
Originally posted by: ingo.dueppe.gmx.de
Sorry, I'm not very familiar with logging.
So how to log debug information? Could you give any example?
Do I have to use the Plugin.getDefault().getLog().log(IStatus) method?
When yes, how should the status object look like?
Thx
Ingo
>Cu, Gunnar
Re: Proper way of logging from plugin [message #216236 is a reply to message #214864] Fri, 26 March 2004 09:24 Go to previous messageGo to next message
I did somthing like this
log.log(new Status(IStatus.INFO, JavadocBuilderPlugin.ID, IStatus.OK,
"Total build time "+(end-start)+" ms", null));
> Thx
> Ingo
>> Cu, Gunnar
general strange problems [message #217576 is a reply to message #213575] Mon, 29 March 2004 14:38 Go to previous message
I have been using Eclipse for a couple of months and every-so-often something stops working.
eg I can't get my properties from a project.
Today, the right button stopped giving me a popup menu so I can't even commit changes to a cvs
repository.
I'm using 2.1.2linux-motif.
Any help would be appreciated.
mas
Previous Topic:Programmatically open a HTML file?
Next Topic:Editor tab tooltip placement dula-head monitor
Current Time: Sun Jul 27 03:04:26 EDT 2025
Powered by FUDForum. Page generated in 0.25947 seconds
