Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Two questions - interpreter library configuration and NewSourceModulePage
| Two questions - interpreter library configuration and NewSourceModulePage [message #20683] |
Fri, 08 February 2008 13:17  |
Originally posted by: a0309169.unet.univie.ac.at
I'm currently in the process of constructing an editor plug-in which
(obviously) utilizes DLTK to provide some functionality.
Since the code of the tutorial plug-in at
http://wiki.eclipse.org/DLTK_IDE_Guide does not seem to be available
anymore, I've downloaded the source of the Ruby plug-in and currently,
based on that, I'm exploring DLTK's functionality.
So far, I've ran into two problems which I couldn't immediately handle:
1. I'm using DLTK facilities to handle interpreter configuration. I have
a problem with AddScriptInterpreterDialog - it requires setting a
default library for the dialog to proceed. I haven't found a way to
automagically configure a default library. Additionally, the language
I'm creating the editor for doesn't even HAVE a concept of a "library".
In short, my question is - how can I get around the problem of setting
the library configuration for the dialog?
2. I've created a new file wizard utilizing NewSourceModuleWizard .
Unfortunately, I receive exceptions when typing in the file name field
of the wizard's Page, namely:
org.eclipse.dltk.ui.wizards.NewSourceModulePage.getFileExten sions(NewSourceModulePage.java:197)
org.eclipse.dltk.ui.wizards.NewSourceModulePage.getFileName( NewSourceModulePage.java:182)
org.eclipse.dltk.ui.wizards.NewSourceModulePage.fileChanged( NewSourceModulePage.java:59)
org.eclipse.dltk.ui.wizards.NewSourceModulePage.access$0(New SourceModulePage.java:51)
org.eclipse.dltk.ui.wizards.NewSourceModulePage$1.dialogFiel dChanged(NewSourceModulePage.java:105)
org.eclipse.dltk.internal.ui.wizards.dialogfields.DialogFiel d.dialogFieldChanged(DialogField.java:68)
org.eclipse.dltk.internal.ui.wizards.dialogfields.StringDial ogField.doModifyText(StringDialogField.java:131)
org.eclipse.dltk.internal.ui.wizards.dialogfields.StringDial ogField.access$0(StringDialogField.java:127)
org.eclipse.dltk.internal.ui.wizards.dialogfields.StringDial ogField$1.modifyText(StringDialogField.java:109)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:166)
However:
-the language toolkit class' getLanguageFileExtensions() method is
implemented with a non-null return value,
-the NewSourceModulePage's getRequiredNature() points to the
corresponding language nature.
What could be another cause for this problem?
Thanks in advance for any help
| Re: Two questions - interpreter library configuration and NewSourceModulePage [message #20698 is a reply to message #20683] |
Wed, 13 February 2008 10:30   |
Hi Mikolaj,
> Hello,
Yes version is outdated, we plan to deliver new improved tutorial to 17 of February,
But you could look to example code from
dev.eclipse.org/cvsroot/technology/org.eclipse.dltk/examples /eclipsecon08/org.eclipse.dltk.examples.python.
Current HEAD version allow configuring of interpreters without any library specified.
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> However:
This could only happen if language toolkit extension point is not correctly contributed.
Please check plugin.xml.
Also you could write simple JUnit test with following code:
IDLTKLanguageToolkit toolkit = DLTKLangaugeManager.getLanguageToolkit("org.eclipse.dltk.tcl.core.nature ");
Andrei Sobolev.
| Re: Two questions - interpreter library configuration and NewSourceModulePage [message #20711 is a reply to message #20698] |
Wed, 13 February 2008 14:47  |
Hello, Andrei,
> Hi Mikolaj,
>> Hello,
Super! DLTK has great potential, but it badly needs introductory
documentation, so what you said is good news.
I would like to supply some pointers in relation to the guide, if it's
not too late:
1. An expanded section on parser construction would prove very useful -
especially on the subject of DLTK AST's structure and usage by the
toolkit. This is something a code-only example does not describe well
unfortunately.
2. Expand on the various UI contributions (especially the editor) - but
I bet you already got into that :).
Yup, already seen them, but had some compile errors, obviously due to
version mismatch (I have 0.9 currently, and the examples probably
require the CVS version). No matter, I'll look into them again.
OK, time for me to check it out then (pun intended ;)).
>> at
>> However:
> Best regards,
> Andrei Sobolev.
Yes, this was the problem - the "nature" field's value for the
org.eclipse.dltk.core.language extension point contribution was invalid
(stupid copy+paste from the contributing class field for the nature).
Thanks for the help and the information!
Mikolaj
Current Time: Fri Nov 07 06:14:16 EST 2025
Powered by FUDForum. Page generated in 0.03828 seconds
