Home » Modeling » GMF (Graphical Modeling Framework) » Audit rule confusion
Audit rule confusion [message #213131] Wed, 10 December 2008 04:01 Go to next message
I have added some audit rule in GMF mapping model to constraint my
model.Somehow the validation doesn't work in the generated editor when
disobeying operation happens.I wonder if I need to add some OCL
constraints in the model definition or in the EMF generated code, and then
apply this Audit rule in the mapping model to make the validation work?
Or if anyone know the reason why only applying Audit rule in mapping
model doesn't work?
Thanks a lot!
Ye Liu
Re: Audit rule confusion [message #213259 is a reply to message #213131] Thu, 11 December 2008 10:50 Go to previous message
Hello yeliu,
Try setting GenDiagram.validationEnabled attribute to true, regenerating
the code + execution validate action in the generated editor (should be registered
after all tehse steps).
Alex Shatalin
Previous Topic:Problem with connection on editor reload
Next Topic:Compartments
Current Time: Sun Aug 31 23:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.06221 seconds
