Home » Eclipse Projects » Eclipse Platform » What is the correct method for defining fragment properties
What is the correct method for defining fragment properties [message #213068] Thu, 18 March 2004 12:39 Go to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Some of the eclipse plugins (org.eclipse.swt.win32) for example use a
fragment.properties file. This actually doesn't seem to work.(either in
2.1.2 or 3.0) Help->About->Configuration Details in 2.1.2
shows
org.eclipse.swt (2.1.2) "Standard Widget Toolkit"
org.eclipse.swt.win32 (2.1.2) "%fragmentName"
Bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=50479
which talks about having fragment properties defined in the
plugins.properties file. I could not find any documentation on a
Should we to use a plugin.properties, fragment.properties or some
combination toprovide the replacement strings for the fragment.xml?
Peter
Re: What is the correct method for defining fragment properties [message #213137 is a reply to message #213068] Thu, 18 March 2004 14:24 Go to previous message
Originally posted by: dj_houghton.nospam.ca.ibm.com
https://bugs.eclipse.org/bugs/show_bug.cgi?id=18617
A related discussion is in the above bug report. I'll make a reference
to it in the current bug report in Equinox.
> shows
> Bugzilla
> Peter
Previous Topic:CVS issue: ignoring of managed files
Next Topic:TableViewer not displaying modified cell value
Current Time: Sat Nov 08 06:21:43 EST 2025
Powered by FUDForum. Page generated in 0.09458 seconds
