Home » Archived » BIRT » Using JNDI to obtain db connection
Using JNDI to obtain db connection [message #213007] Mon, 22 January 2007 06:54 Go to next message
My application works under JBoss application server and I use BIRT
engine runtime to generate reports (version 2.1.1).
The problem - BIRT not use defined JNDI string to obtain database
connection. It always create new connection by using other
oda-data-source parameters.
The data-source part of my rptdesign file:
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="CRM2DS" id="4">
<text-property name="displayName">CRM2DS</text-property>
<property
name="odaDriverClass">com.mysql.jdbc.Driver</property>
<property name="odaURL">jdbc:mysql://localhost/CRM2</property>
<property name="odaUser">root</property-->
<property name="odaJndiName">java:comp/env/CRM2DS</property>
</oda-data-source>
</data-sources>
How can I force BIRT engine to use JNDI to obtain connection to database?
Thanks in advance
Cloding db connections after report generation [message #213040 is a reply to message #213007] Mon, 22 January 2007 10:16 Go to previous messageGo to next message
During report generation BIRT report engine open database connection,
uses the connection but it does not close it after report generation is
done. As a result MySQL reports "Too many connections" after a lot of
reports are generated.
Why does not BIRT release database connection after report generation?
Whats wrong?
Re: Cloding db connections after report generation [message #213089 is a reply to message #213040] Mon, 22 January 2007 12:47 Go to previous messageGo to next message
Did you get the connection using JNDI?
Can you try
java:/CRM2DS.
If your connection is not being closed please log a bugzilla entry.
Also we just wrote an artilce on JBOSS deployment at eclipsemag.net.
I believe you can download it for free.
Jason
"Sergey A. Lisovoy" <s.lisovoy@spb.solidworks.ru> wrote in message
news:ep2kc0$5ui$1@utils.eclipse.org...
> During report generation BIRT report engine open database connection, uses
> the connection but it does not close it after report generation is done.
> As a result MySQL reports "Too many connections" after a lot of reports
> are generated.
> Whats wrong?
Re: Cloding db connections after report generation [message #213990 is a reply to message #213089] Thu, 25 January 2007 05:38 Go to previous messageGo to next message
I have read article at eclipsemag, but I'm using report engine (not web
viewer) into my application. So I cant find an answers on my question...
About JNDI: I have solved problem with JNDI by placing jndi.properties
in
<ReportEngine> \plugins\org.eclipse.birt.report.data.oda.jdbc_2.2.0.I200612 22\drivers\
folder.
but connection still open after report generation. It seems to be a
bug... I will try to add report to bugzilla and waiting for fix. :(
Thanks for your answers.
> Can you try
> java:/CRM2DS.
> Jason
>> are generated.
>> Whats wrong?
Re: Cloding db connections after report generation [message #213998 is a reply to message #213089] Thu, 25 January 2007 06:04 Go to previous messageGo to next message
Add a bug to bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=171640
> Can you try
> java:/CRM2DS.
> Jason
>> are generated.
>> Whats wrong?
Re: Cloding db connections after report generation [message #214094 is a reply to message #213998] Thu, 25 January 2007 11:11 Go to previous message
Thanks.
Jason
news:epa2og$bj5$1@utils.eclipse.org...
>> Can you try
>> java:/CRM2DS.
>> Jason
>>> Whats wrong?
Previous Topic:Birt Web Based Designer
Next Topic:Creating a sql select with an IN clause
Current Time: Wed Oct 22 18:10:55 EDT 2025
Powered by FUDForum. Page generated in 0.26319 seconds
