Home » Archived » BIRT » PDF Report as PDF does not work
PDF Report as PDF does not work [message #212915] Sun, 21 January 2007 09:05 Go to next message
Originally posted by: janos.varadi.googlemail.com
------=_NextPart_000_000D_01C73D6D.874A1FA0
Content-Type: text/plain;
charset="iso-8859-1"
I try to use the function "View Report as PDF" but I always get the =
Error message=20
org.eclipse.birt.report.service.api.ReportServiceException: Report =
engine fails to create extension to handle this request
After googeling I found one solution for this problem
I downloaded the itetxt1.3.jar and copied it to the folder
plugins/com.lowagie.itext_*/lib
but I still get the same error message.=20
System Information:
Eclipse 3.3
Birt Version 2.1.1
Thanks a lot for your help
J=E1nos V.
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>I try to use the function "View Report =
as PDF" but=20
I always get the Error message </FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial=20
size=3D2><EM>org.eclipse.birt.report.service.api.ReportServiceException: =
Report=20
engine fails to create extension to handle this =
request</EM></FONT></DIV>
<DIV><EM><FONT face=3DArial size=3D2></FONT></EM>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>After googeling I found one solution =
for this=20
problem</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I downloaded the itetxt1.3.jar and =
copied it to the=20
<FONT face=3D"Times New Roman" size=3D3>folder</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3D"Times New Roman"=20
size=3D3></FONT></FONT>&nbsp;</DIV>
size=3D3>plugins/com.lowagie.itext_*/lib</FONT></FONT></DIV >
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>but I still get the same error message. =
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>System Information:</FONT></DIV><FONT =
face=3DArial=20
size=3D2>
<DIV><BR>Eclipse 3.3</DIV>
<DIV>Birt Version 2.1.1</DIV>
<DIV></FONT><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Thanks a lot for your help</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>J=E1nos V.</FONT></DIV></BODY></HTML>
------=_NextPart_000_000D_01C73D6D.874A1FA0--
Re: PDF Report as PDF does not work [message #213110 is a reply to message #212915] Mon, 22 January 2007 14:07 Go to previous message
------=_NextPart_000_000D_01C73E2E.B018C6E0
I believe 2.1.1 is only tested with Eclipse 3.2. You can either get the =
2.2 m4 build or try the allinone download and copy the iText lib.
Keep in mind 2.1.1 uses iText 1.3 and 2.2m4 uses iText 1.4.6.
Jason
"Janos Varadi" <janos.varadi@googlemail.com> wrote in message =
news:eovrun$5jt$1@utils.eclipse.org...
Error message=20
System Information:
Eclipse 3.3
Birt Version 2.1.1
J=E1nos V.
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2963" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I believe 2.1.1 is only tested with =
Eclipse=20
3.2.&nbsp; You can either get the 2.2 m4 build or try the allinone =
download and=20
copy the iText lib.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Keep in mind 2.1.1 uses iText 1.3 and =
2.2m4 uses=20
iText 1.4.6.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Jason</FONT></DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Janos Varadi" &lt;<A=20
href=3D"mailto:janos.varadi@googlemail.com">janos.varadi@googlemail.com</=
A>&gt;=20
wrote in message <A=20
href=3D"news:eovrun$5jt$1@utils.eclipse.org">news:eovrun$5jt$1@utils.ecli=
pse.org</A>...</DIV>
<DIV><FONT face=3DArial size=3D2>I try to use the function "View =
Report as PDF"=20
but I always get the Error message </FONT></DIV>
Report=20
for this=20
copied it to=20
the <FONT face=3D"Times New Roman" size=3D3>folder</FONT></FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>but I still get the same error =
message.=20
</FONT></DIV>
face=3DArial=20
size=3D2>
<DIV><FONT face=3DArial size=3D2>Thanks a lot for your =
help</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>J=E1nos =
V.</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000D_01C73E2E.B018C6E0--
Previous Topic:Formatting Numbers inside a Text Field
Next Topic:Including JavaScript in SVG Chart
Current Time: Thu Jul 24 08:04:37 EDT 2025
Powered by FUDForum. Page generated in 0.03841 seconds
