| Help System Indexing Question [message #212850] |
Thu, 18 March 2004 08:20  |
Originally posted by: swoolley.hursley.ibm.com
Whilst performing a search in the help system of my runtime workbench
(V2.1.2), I noticed a few messages being written to the console in my
development workbench (also V2.1.2). They looked like this (copied directly
form the console):
Parse Aborted: Encountered "<EOF>" at line 67, column 7534.
Was expecting:
<CloseQuote2> ...
Parse Aborted: Encountered "<EOF>" at line 31, column 1932.
Was expecting one of:
<ArgName> ...
<TagEnd> ...
Parse Aborted: Encountered "<EOF>" at line 37, column 1524.
Was expecting:
<CloseQuote2> ...
I have identified the doc plug-in that is causing these errors, but am
unable to narrow it down to the file(s) that are causing these errors to be
thrown.
Any help gratefully received!
Best wishes,
Steve
| Re: Help System Indexing Question [message #213263 is a reply to message #212850] |
Thu, 18 March 2004 22:44   |
You have several options;
1. If you have access, use chkpii tool.
2. In PDE launch configuration, enable tracing and set
org.eclipse.help/debug/search property to true. It will list every file
being indexed.
3. Copy eclipse\plugins\org.eclipse.help_2.1.2\.options to
eclipse\directory. and set value org.eclipse.help/debug/search to true.
Launch eclipse with "-debug" switch.
4. Import org.apache.lucene plug-in, put a break-point in
org.apache.lucene.demo.html.ParseException.
Konrad
"Stephen Woolley" <swoolley@hursley.ibm.com> wrote in message
news:c3c7g3$bvk$1@eclipse.org...
directly
> form the console):
> Was expecting:
> <CloseQuote2> ...
> <ArgName> ...
> <TagEnd> ...
> Was expecting:
> <CloseQuote2> ...
be
> thrown.
> Best wishes,
> Steve
| Re: Help System Indexing Question [message #213583 is a reply to message #213263] |
Fri, 19 March 2004 11:20  |
Also, try running HTMLTidy (http://tidy.sf.net) against the (X)HTML in
your plugin. It'll quickly tell you where you've got DTD errors in your
HTML files.
Dan
> being indexed.
> Konrad
>>Hi,
> directly
>>form the console):
>>Was expecting:
>> <CloseQuote2> ...
>> <ArgName> ...
>> <TagEnd> ...
>>Was expecting:
>> <CloseQuote2> ...
> be
>>thrown.
>>Best wishes,
>>Steve
FUDForum. Page generated in 0.04853 seconds
