Home » Modeling » GMF (Graphical Modeling Framework) » Create Connection between two Nodes programmatically (newbie)
Create Connection between two Nodes programmatically (newbie) [message #212495] Sat, 29 November 2008 16:58 Go to next message
Originally posted by: descipar.gmail.com
Hello all!
I guess this is really a newbie question, but sadly I can`t get it to
work on my own. :(
I want to create a connection between to 2 Nodes which are created
briefly before.
Node creation works fine, but i`m stuck with the connection part
My Code to create a Node looks like this:
CreationTool tool = new CreationTool(
GridConfigurationElementTypes.Building_2003);
CreateViewAndElementRequest req =
(CreateViewAndElementRequest)tool.createCreateRequest();
CreateViewAndOptionallyElementCommand createCmd =
new CeateViewAndOptionallyElementCommand(
req.getViewAndElementDescriptor().getElementAdapter(),
(GridConfigurationEditPart) selection.getFirstElement(),
null, req.getViewAndElementDescriptor()
.getPreferencesHint());
ICommandProxy cmdProxy = new ICommandProxy(createCmd);
cmdProxy.execute();
This is executed for nodes and then I tried to create a connection like
this:
Command createCMD3 = CreateConnectionViewAndElementRequest
.getCreateCommand(
GridConfigurationElementTypes.BuildingSmartMeterRelation_400 1,
sourceEditPart, targetEditPart); createCMD3.execute();
The part which I do not know, is how to get the sourceEditPart and
targetEditPart.
I would guess it is fairly simple...
Hope someone can help me!
Kai
Re: Create Connection between two Nodes programmatically (newbie) [message #212497 is a reply to message #212495] Sun, 30 November 2008 12:19 Go to previous messageGo to next message
Nobody a clue how to get this done?
Any advise is appreciated...
And sorry for posting twice, but this is quite important for me.
Thanks again
Kai Schulte wrote:
> Hello all!
> work on my own. :(
> briefly before.
> cmdProxy.execute();
> this:
> .getCreateCommand(
> targetEditPart.
> Kai
Re: Create Connection between two Nodes programmatically (newbie) [solved] [message #212554 is a reply to message #212497] Mon, 01 December 2008 12:20 Go to previous message
Solved it. I guess not really in a fine way, but it works.
I put the corresponding code here in case someone has the same problem.
Kai
* Getting the current EditPart. Should always be the last one.
* After creating the Node
BuildingEditPart buildingEditPart = null;
ListIterator buildingIte = buildingGridEditPart.getTargetEditPart(
buildingRequest).getChildren().listIterator();
while (buildingIte.hasNext()) {
EditPart editPart = (EditPart) buildingIte.next();
if (buildingIte.hasNext() == false) {
buildingEditPart = (BuildingEditPart) editPart;
* Create connection
IElementType buildingSmartMeterElementType =
GridConfigurationElementTypes.BuildingSmartMeterRelation_400 1;
buildingSmartMeterRequest = new CreateConnectionViewAndElementRequest(
buildingSmartMeterElementType,
((IHintedType) buildingSmartMeterElementType)
.getSemanticHint(), PreferencesHint.USE_DEFAULTS);
Command buildingSmartMeterCmd = buildingSmartMeterRequest
.getCreateCommand(buildingSmartMeterRequest,
buildingEditPart, smartMeterEditPart);
buildingSmartMeterCmd.execute();
> Thanks again
> Kai Schulte wrote:
>> Hello all!
>> work on my own. :(
>> briefly before.
>> cmdProxy.execute();
>> like this:
>> .getCreateCommand(
>> targetEditPart.
>> Thanks,
>> Kai
Previous Topic:Target Decoration of Polyline Connection
Next Topic:TopDownCompositeLayout zoom level bugs
Current Time: Wed Nov 05 23:43:27 EST 2025
Powered by FUDForum. Page generated in 0.04269 seconds
