Home » Eclipse Projects » GEF » Tree viewer and Drag and Drop DND.DND_COPY
Tree viewer and Drag and Drop DND.DND_COPY [message #212453] Thu, 23 March 2006 03:31 Go to next message
Originally posted by: mateu.yabar.justinmind.com
I want to use drag and drop between trees (treeviewers) and I have found
that when I try to use the DND_COPY (DnD with control key) it doesn't work.
I've been looking for a while and I have seen that this doesn't work because
TreeViewerTransferDropListener doesn't enable it:
public boolean isEnabled(DropTargetEvent event) {
if (event.detail != DND.DROP_MOVE)
return false;
return super.isEnabled(event);
It is impossible to extend TreeViewerTransferDropListener because its a
private class. What I'm doing now is copying the
TreeViewerTransferDropListener source code and changing it to achive this
results. However I think that it should be a better way to do it. Any
suggestions?
Re: Tree viewer and Drag and Drop DND.DND_COPY [message #212587 is a reply to message #212453] Mon, 27 March 2006 14:30 Go to previous message
Basically, you have to do what you said. Note that in many cases the drop
listener implicitly changes the operation to a COPY. You can do this as well
in your code.
"exquisitus" <mateu.yabar@justinmind.com> wrote in message
news:dvtmd5$ic9$1@utils.eclipse.org...
> work. I've been looking for a while and I have seen that this doesn't work
> because TreeViewerTransferDropListener doesn't enable it:
> return false;
> suggestions?
> Thanks
Previous Topic:GEF Popup Toolbar
Next Topic:Eclipse Commands != GEF Commands?
Current Time: Mon Oct 20 15:34:29 EDT 2025
Powered by FUDForum. Page generated in 0.04086 seconds
