Home » Eclipse Projects » Eclipse Platform » Bug in VerifyEvent handling?
Bug in VerifyEvent handling? [message #212373] |
Wed, 17 March 2004 13:13  |
Originally posted by: burner.zclipse.org
I have the following Editor pasted below, where it _should_ input 'A'
instead of 'a' and 'B' instead of 'b', however, only the untyped Listener
appears to be working. According to the API on VerifyEvent, I should be
able to change the text field to change the text that will be inserted.
However, this only works when I do it to the Event object in my untyped
Listener. Also, Event.character isn't set for the untyped Listener, but I
don't know if it supposed to be or not.
mike
(this is doing PDE on 3.0.200403100800)
* Created on Mar 16, 2004
* $Id$
package org.zclipse.extremities.editors;
import org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor ;
import org.eclipse.jface.text.source.IOverviewRuler;
import org.eclipse.jface.text.source.ISourceViewer;
import org.eclipse.jface.text.source.IVerticalRuler;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.VerifyKeyListener;
import org.eclipse.swt.events.VerifyEvent;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.ui.editors.text.TextEditor;
* TODO: Document ExtremityJavaEditor
* @author <a href="mailto:burner@zclipse.org">Michael R. Head</a>
* @version $Name$ $Date$ $Revision$
public class ExtremityJavaEditor extends TextEditor {//CompilationUnitEditor {
/* (non-Javadoc)
* @see org.eclipse.ui.IWorkbenchPart#createPartControl(org.eclipse. swt.widgets.Composite)
public void createPartControl(Composite parent) {
// TODO Auto-generated method stub
super.createPartControl(parent);
getSourceViewer().getTextWidget().addVerifyKeyListener(new VerifyKeyListener() {
public void verifyKey(VerifyEvent event) {
System.out.println("Verifying Key:"+event);
if(event.character == 'a' && event.stateMask == 0) {
event.text="A";
event.keyCode = 97;
event.character = 'A';
System.out.println("Verified Key"+event);
getSourceViewer().getTextWidget().addListener(SWT.Verify, new Listener() {
public void handleEvent(Event event) {
if(event.type == SWT.Verify) {
System.out.println("Handling Verify:"+event+", event.character="+event.character+", event.text=\""+event.text+"\"");
if(event.text.equals("b") && event.stateMask == 0) {
event.text="B";
event.keyCode=98;
event.character = 'B';
System.out.println("Handled Verify:"+event+", event.character="+event.character+", event.txt=\""+event.text+"\"");
/* (non-Javadoc)
* @see org.eclipse.jdt.internal.ui.javaeditor.JavaEditor#createJava SourceViewer(org.eclipse.swt.widgets.Composite, org.eclipse.jface.text.source.IVerticalRuler, org.eclipse.jface.text.source.IOverviewRuler, boolean, int)
//protected ISourceViewer createJavaSourceViewer(Composite parent, IVerticalRuler verticalRuler, IOverviewRuler overviewRuler, boolean isOverviewRulerVisible, int styles) {
//return super.createJavaSourceViewer(parent, verticalRuler,
// overviewRuler, isOverviewRulerVisible, styles);
http://zclipse.org
Re: Bug in VerifyEvent handling? [message #212805 is a reply to message #212771] |
Thu, 18 March 2004 06:47  |
On Thu, 18 Mar 2004 09:04:53 +0100, Tom Eicher wrote:
> You are listening to two different kinds of events: VerifyKey and Verify
> are different. VerifyKey allows you to check every typed character /
> keyboard input, Verify allows you to veto changes about to be entered
> into the text component.
OK, fair enough, but then why does the documentation (in 3.0M7) for
VerifyEvent say that you can change the "text" field to change the text
that will be inserted? That's really what's confusing.
After looking closer, it's just this piece of documentation that is
misleading. VerifyEvent is used by two different listeners (VerifyListener
and VerifyKeyListener). As you say, VerifyListener lets you modify the
input from the user in the VerifyEvent (or abort processing of the event),
whereas the VerifyKeyListener is specific to StyledText and only allows
you to abort the processing of a key stroke.
VerifyKeyListener.verifyKey() explicitly says which fields of VerifyEvent
are used. Perhaps the documentation on VerifyEvent.text should not specify
how it will be used, and leave that up to the individual Listener
interfaces that will use the event.
Anyway, thanks for setting me straight, mike
> -tom
http://zclipse.org
Current Time: Sun Aug 31 18:45:50 EDT 2025
Powered by FUDForum. Page generated in 0.04079 seconds
