| Problem about key binding! [message #212234] |
Mon, 20 March 2006 04:51  |
Originally posted by: java.freshman.cx.gmail.com
Hi, all.
In my project, I need to bind key "CTRL+A" to my customized
SelectAllAction by installing KeyHandler to my editor to handler keyboard
event.
It works well when the runtime platform is eclipse workbench, but the key
binding doesn't work with RCP platform.
What is the problem in deed on RCP platform? And what should I do
additionally?
Also, I am wondering is there any solution of key binding.
How about extending the extension points "binding" and "command"?
Thanks a lot!
| Re: Problem about key binding! [message #212499 is a reply to message #212490] |
Thu, 23 March 2006 20:16  |
Hi, Steven,
I tried this solution before. But it seems not to work well.
"CTRL+A" is always diabled in RCP environment.
Steven Shaw wrote:
> I think the proper way to is to declare your action with an global ID using
> the org.eclipse.ui.actions.ActionFactory.SELECT_ALL.getId().
> Then you need to override the GraphicalEditor#createActions method and
> register your SelectAllAction.
> -Steve
> "Shawn Chen" <java.freshman.cx@gmail.com> wrote in message
> news:52dfeaa4f0fa27e81e74724b12853804$1@www.eclipse.org...
>> Hi, all.
>> event.
>> additionally?
>> Thanks a lot!
FUDForum. Page generated in 0.04060 seconds
