Home » Language IDEs » C / C++ IDE (CDT) » Build Problem
Build Problem [message #212210] Fri, 21 March 2008 04:14 Go to next message
Originally posted by: hajer.jelloul.ardia.com.tn
Dear Sir,
I have installed Eclipse version 3.3.2
With Eclipse CDT and zylin plugin
I have on my PC the version 1.6.0_05 of java runtime
I also installed gcc version 4.2.2 and gnu make version 3.81
I wanted to test my environment so I created a simple project by following
the instructions described in this link
http://www.yagarto.de/howto/yagarto2/index.html#feature but I have not
succeeded to compile When I chose clean… from menu project, I got this
message:
**** Clean-only build of configuration Default for project NDTU_SW ****
make clean
MAKE Version 5.2 Copyright (c) 1987, 2000 Borland
rm -f NDTU_SW.o NDTU_SW.exe
AllocationBase 0x0, BaseAddress 0x71590000, RegionSize 0x450000, State
0x10000
C:\Program Files\yagarto-tools-20070303\bin\rm.exe: *** Couldn't reserve
space for cygwin's heap, Win32 error 487
** error 1 ** deleting clean
And then when I build project I got this message
**** Build of configuration Default for project NDTU_SW ****
make all
Fatal: 'NDTU_SW.o' does not exist - don't know how to make it
Note: I have tried to test the Ethernut3Test example, but I have not
succeeded I got this message
**** Clean-only build of configuration Default for project Ethernut3Test
make clean
Error makefile 113: Too many rules for target '%o'
Error makefile 134: Command syntax error
*** 2 errors during make ***
Please tell me what's the origin of this problem is my first time that I
use Eclipse.
Re: Build Problem [message #212220 is a reply to message #212210] Fri, 21 March 2008 05:07 Go to previous messageGo to next message
Hajer wrote:
> Dear Sir,
> make clean
> 0x10000
These 2 messages show that you have a mixed Borland / Cygwin
environment. You use Borland's make an Cygwin's rm.exe.
> use Eclipse.
The origin of your problem is at least the mixed environment. You should
use only an Eclipse CDT supported environment (and I think on Windows
that is either Cygwin or MingW and not Borland or VC). Setting Cygwin's
path before Borland's path will probably do the trick.
Joost
Re: Build Problem [message #212543 is a reply to message #212220] Tue, 25 March 2008 05:33 Go to previous messageGo to next message
Thank you for your answer.
I uninstalled all the others environment and I have left only the Eclipse
CDT environment, but I have problem. when I do clean, I get this message:
**** Clean-only build of configuration Default for project NDTU ****
make clean
rm -f NDTU.o NDTU.exe
0x10000
make: *** [clean] Error 1
And after build I have this message
**** Build of configuration Default for project NDTU ****
make all
g++ -O2 -g -Wall -fmessage-length=0 -c -o NDTU.o NDTU.cpp
process_begin: CreateProcess(NULL, g++ -O2 -g -Wall -fmessage-length=0 -c
-o NDTU.o NDTU.cpp, ...) failed.
make (e=2): Le fichier spécifié est introuvable.
make: *** [NDTU.o] Error 2
in my Makefile you find this:
CXXFLAGS = -O2 -g -Wall -fmessage-length=0
OBJS = NDTU.o
LIBS =
TARGET = NDTU.exe
$(TARGET): $(OBJS)
$(CXX) -o $(TARGET) $(OBJS) $(LIBS)
all: $(TARGET)
clean:
rm -f $(OBJS) $(TARGET)
Have you any idea about this problem?
Re: Build Problem [message #212566 is a reply to message #212543] Tue, 25 March 2008 06:56 Go to previous message
I have seen the following reasons for simular problems (hint: google for
"Couldn't reserve space for cygwin's heap, Win32 error 487 ")
- multiple cygwin dll's
- interference of anti virus software (all brands)
- too many open files in the Cygwin environment
- old version of the Cygwin dll
Gr
Joost
Previous Topic:How to reconnect svn repository after ip address changed?
Next Topic:completion request
Current Time: Fri Jun 06 23:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.03017 seconds
