Home » Archived » BIRT » Cannot run RCPEngine example
Cannot run RCPEngine example [message #212208] Wed, 17 January 2007 15:40
Originally posted by: aparasur.ugs.com
I am trying to run the RCP Engine example, but am getting the stack trace
shown below.
I am running this example from the BIRT 2.1.1. All-in-One bundle.
What could be the problem?
Thanks in advance.
-Arvind
Jan 17, 2007 12:35:48 PM
org.eclipse.birt.report.model.metadata.StructRefPropertyType validateValue
INFO: The value of the structure property is a string
Jan 17, 2007 12:35:56 PM
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask
createContentEmitter
SEVERE: Error.OutputFormatNotSupported
org.eclipse.birt.report.engine.api.UnsupportedFormatExceptio n: The output
format html is not supported.
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.cre ateContentEmitter(RunAndRenderTask.java:86)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:155)
at org.eclipse.birt.examples.rcpengine.View.previewReport(View. java:243)
at org.eclipse.birt.examples.rcpengine.View.access$1(View.java: 205)
org.eclipse.birt.examples.rcpengine.View$3.widgetSelected(Vi ew.java:179)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
org.eclipse.birt.examples.rcpengine.Application.run(Applicat ion.java:18)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Previous Topic:error trying to write birt chart to png
Next Topic:BIRT_VIEWER_LOG_LEVEL - 'ALL' not working
Current Time: Thu Nov 06 11:44:35 EST 2025
Powered by FUDForum. Page generated in 0.03515 seconds
