Home » Archived » BIRT » Report Designer Option
Report Designer Option [message #20541] Fri, 18 March 2005 00:31 Go to next message
Originally posted by: swati_roighare.persistent.co.in
I have installed the necessary software required for the BIRT.
But when i try to access the BIRT - Report Designer option through the
Open Perespetive option of the Eclipse editor, its not available there.
I checked the Eclipse -> Plugin folder. But i didnt find any
org.eclipse.birt files there.
Have I missed some installable?
But as per the list of software installable given in the BIRT tutorial, I
have installed all the necessary software.
Can anyone tell me what might be the problem?
Swati
Re: Report Designer Option [message #20560 is a reply to message #20541] Fri, 18 March 2005 02:39 Go to previous messageGo to next message
Originally posted by: eros.design.gmail.com
On Fri, 18 Mar 2005 05:31:52 +0000 (UTC), swati =
<swati_roighare@persistent.co.in> wrote:
maybe you can delete your config folder in'eclipse' and try to re-launch=
eclipse
www.chinaui.org
Re: Report Designer Option [message #20578 is a reply to message #20560] Fri, 18 March 2005 04:57 Go to previous messageGo to next message
Thanks a lot eros.
It worked.
Swati
> eclipse
Re: Report Designer Option [message #20610 is a reply to message #20578] Fri, 18 March 2005 12:44 Go to previous message
>> re-launch eclipse
Just FYI -- apparently in Eclipse 3.1+ this is not recommended.
Suggested procedure is running Eclipse just once with the -clean
parameter, ie;
C:\Eclipse\eclipse.exe -clean
Nigel
Previous Topic:Problem with Tutorial
Next Topic:3.1 support
Current Time: Sat Nov 08 21:56:08 EST 2025
Powered by FUDForum. Page generated in 0.03946 seconds
