Home » Language IDEs » ServerTools (WTP) » tomcat-juli.jar not on classpath in tomcat6
tomcat-juli.jar not on classpath in tomcat6 [message #211752] Thu, 03 April 2008 12:19 Go to next message
Originally posted by: adam.hardy.no.spam.cyberspaceroad.spam
I have a project which uses the Tomcat Jasper code to precompile JSPs. Jasper is
currently on the classpath via the Apache Tomcat 6 plugin.
However, I run into this when using it:
java.lang.NoClassDefFoundError: org/apache/juli/logging/LogFactory
at org.apache.jasper.servlet.JspServlet.<init>(JspServlet.java:60)
and I checked what's what and my tomcat installation has tomcat-juli.jar in its
/bin directory and the jar doesn't make it into the classpath available to the
project.
It's OK running in-container, this is fine - however I would like to use tomcat
running just as a dependency of a JUnit test.
As a work-around, I copied the tomcat-juli.jar from tomcat/bin to tomcat/lib. It
seems to accept the duplication of the jar.
What about future? Is it probable that the tomcat plugin will have to
incorporate the tomcat/bin dir into the classpath?
Adam
Re: tomcat-juli.jar not on classpath in tomcat6 [message #211761 is a reply to message #211752] Thu, 03 April 2008 12:37 Go to previous messageGo to next message
> Jasper is currently on the classpath via the Apache Tomcat 6 plugin.
> in its /bin directory and the jar doesn't make it into the classpath
> available to the project.
> tomcat running just as a dependency of a JUnit test.
> tomcat/lib. It seems to accept the duplication of the jar.
> Thanks
> Adam
When using the WTP Tomcat support, tomcat-juli.jar will automatically be
included on the "classpath" due to its presence in the Class-Path
attribute found in the MANIFEST.MF file in Tomcat 6's bootstrap.jar. If
you launch Tomcat in a way that doesn't honor this Class-Path attribute,
then you would need to add it, and possibly others in that list, manually.
Larry
Re: tomcat-juli.jar not on classpath in tomcat6 [message #211781 is a reply to message #211761] Fri, 04 April 2008 06:03 Go to previous message
>> tomcat-juli.jar in its /bin directory and the jar doesn't make it into
>> the classpath available to the project.
>> use tomcat running just as a dependency of a JUnit test.
>> Thanks
>> Adam
OK, I will follow that. Thanks alot.
Adam
Previous Topic:projects missing from J2EE module dependencies
Next Topic:MalformedInputException on tag files
Current Time: Mon Sep 01 01:42:40 EDT 2025
Powered by FUDForum. Page generated in 0.05384 seconds
