Having trouble with PDT and Xdebug on mac intel [message #20483] |
Mon, 14 May 2007 12:40  |
Originally posted by: sudeshna_das.harvard.edu
I am having trouble using Xdebug on Mac intel. I am using PDT RC3. I am
using PHP 5.1.6, Eclipse 3.2.2 and Apache 2.0. My php.ini is initialized
as follows:
[DEBUGGER]
zend_extension=/Applications/MAMP/Library/share/php/xdebug.s o
Xdebug.remote_enable=1
xdebug.remote_handler=dbgp
xdebug.remote_mode=req
xdebug.remote_host=127.0.0.1
xdebug.remote_port=9000
xdebug.idekey=sdas
The script doesn't halt at breakpoints and I get this message
<terminated>Watch a drupal request [PHP Web Page]
<terminated>Session Terminated
Does PDT/Xdebug not work on Mac intels?
Thanks for any help!
Sudeshna
Re: Having trouble with PDT and Xdebug on mac intel [message #20508 is a reply to message #20502] |
Mon, 14 May 2007 14:53   |
Sudeshna,
Did you follow the instructions in the pdf file that comes with the plugin?
Also, don't define the idekey, it is set to ECLIPSE_XDEBUG by default,
so you might wanna omit that line, restart everything and try over.
I had the same issue not so much ago, and David was a great help, so now
I will tell you what he told me :)
First make sure that you are editing the same php.ini file PHP is using,
you can see that by executing a phpinfo().
If you are editing the correct file, send us you phpinfo() page, maybe
there is something there that you are missing.
Ali
sdas wrote:
> Thanks, I installed your XDebug plugin (compiled version), but it still
> doesn't halt at the breakpoint.
> Now I get the following on my debug window:
> Watch a drupal request [PHP Web Script with XDebug]
> Remote Launch
> Sudeshna
FUDForum. Page generated in 0.31491 seconds
