Home » Archived » BIRT » Empty row set problem for chart
Empty row set problem for chart [message #211528] Mon, 15 January 2007 08:06 Go to next message
Originally posted by: vgryn.yahoo.com
Hi!
Using BIRT 2.2M2.
I created Bar chart with lots of complex expressions over the data set, such
as
row[...].toSrting()
When row set for chart is empty (include after chart row set filtering), bar
chart is not displayed at all. Also it causes errors in preview mode
(toString() obviously cannot be evaluated).
I would like to display some sort of message or so in such case.
Question 1. Is it possible somehow to check in run-time if row set for chart
is empty from outside of the chart object?
Question 2. Is it possible to check above from inside (in the chart
scripts)?
Question 3. Is it possible to draw something custom inside of the chart? Can
I hide plot and legend areas and leave just chart title to display a
message? I know I can, but would not BIRT evaluate Plot area expression
(like row[...].toSrting()) anyway and thus entire chart fails because
errors?
Note that I cannot just check data - because chart contains filtering as
well (that is changed dynamically by user input).
General question is: does BIRT contain any features for charts to deal with
empty row sets?
WBR,
Vlad Grynchyshyn
Re: Empty row set problem for chart [message #211552 is a reply to message #211528] Mon, 15 January 2007 08:25 Go to previous message
You could try to check for null in your expression.
if ( row[...] != null )
row[...].toString();
This will generate null points that are handled by the chart engine. The
problem you're seeing is a javascript evaluation error from the Rhino JS
engine, when calling toString() on a null object.
We decided not to ignore script errors while rendering the chart, so that
the designer could see them, otherwise they might go unnoticed in production.
David
> Hi!
> Using BIRT 2.2M2.
> set, such
> as
> row[...].toSrting()
> filtering), bar
> chart is empty from outside of the chart object?
> scripts)?
> chart? Can I hide plot and legend areas and leave just chart title to
> display a message? I know I can, but would not BIRT evaluate Plot area
> expression (like row[...].toSrting()) anyway and thus entire chart
> fails because errors?
> as well (that is changed dynamically by user input).
> with empty row sets?
Previous Topic:Pie wedge dynamic (script) coloring issues
Next Topic:Cairo error with BIRT charts on Solaris
Current Time: Sun Aug 31 09:52:50 EDT 2025
Powered by FUDForum. Page generated in 0.02623 seconds
