Break between connection and ellipse [message #211519] |
Wed, 19 November 2008 07:38  |
Originally posted by: torsten.rieger.promatis.de
--------------070006000502010004050701
i have a problem with the connections to a ellipse. There is alsway a
break between the two figures. It looks like there is a invisible
rectangle around the ellipse (look at the attachment).
I tried so much but i don't find the mistake. :-(
Can anybody help me?
Greets
Torsten
Content-Type: image/jpeg;
name="elliptical.jpeg"
Content-Disposition: inline;
filename="elliptical.jpeg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAsICAoIBwsKCQoNDAsNERwSEQ8P ESIZGhQcKSQr
KigkJyctMkA3LTA9MCcnOEw5PUNFSElIKzZPVU5GVEBHSEX/2wBDAQwNDREP ESESEiFFLicu
RUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVFRUVF RUVFRUX/wAAR
CADLARoDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD1yiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiikZlRSzEKo6knpQAtFQfaHl/49 4yw/vv8AKv8A
iaPJmf79wV9o1A/nmgCeioPsiH70kx/7asP5Gj7InZ5h/wBtWP8AM0AT0VB5 Eq/cuH+jqGH9
D+tHmzRf62Lev96Ln9Ov5ZoAnopscqTLujYMPanUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFADJZVhjLtn0AHUn0FRJA0rC S5wWHKx9VT/E
+9C/vrtmP3IflX/eI5P5ED86sUAFFFFABRRRQAUUUUAQy24ZvMjPly/3gOvs R3FLDMZNyONs
qfeX+o9qlqvdLsUXCj5ouT7r3H+fSgCxRQCCMjoaKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKAILT/VuT1Mr5/76P9MVPUEZ8u6k jPR/3i/yI/r+
NT0AFFFFABRRRQAUUUUAFIwBUhuhHNLUF2x8ny0+/L8i+2ep/Ac0ALZkmygL dfLXP5VNSKoV
Qo4AGBS0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
ARzReaowdrqcq3oaSGfzCY3GyVeq/wBR6ipaZLCkwG8cjkMDgj6GgB9FV83E PUCdPUYDf4H9
KUXsPR28s+kgK/zoAnopqyI/3WVvoc0pZV+8QPqaAFoqFryAHAkDt/dT5j+Q pPMnl/1cflj+
9J1/AD+tAEk0yQrlzyeAo5LH0ApkUbFzNN98jAX+4PT6+tLFbrGxckvIert1 /D0qWgAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiopZx GwRQXkPRF/mf
QUASM6opZ2CqOpNQbpLn7mYov72Pmb6elKkBZhJcEO45Cj7q/T1PvU9ADURY 0CoMKO1OoooA
KMZ60UUARNa27/egib6oDSCztl+7bxD6IKmooAAoUYUAD0FFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFBIAJJwB3NRyzpDgHLOfuo vJNRiB5iGucY
6iIfdH19f5UAHmyXHEHyR95SOv8Auj+v86lihSFSEHXkk8kn3NPooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoop ksyQqC568ADk
k+woAfVcztMStsAR0Mp+6Pp6mk8qS55n+SPtEDyf94/0/nVkAKAAAAOgFAEc UCxZIyzt9525
JqSiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACimySJEhZ2CioNstz97dFD/AHejN9fQfrQA552ZzHbgO44Zj91f r6n2p0VuI2Ls
S8p6u38h6CpERY1CooVR0ApaACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAoooJCgkkADqTQAUjMFBLEADuTUHmy3H+pGyP/AJ6MOT9B/U05bSIN ucGR/wC9Ic//
AFh+FACfbIT9xmk/65qW/UUfaWP3baY/go/manooAg+0Sd7WYfin/wAVR9rQ ffjlT6xk/wAq
nooAZHPFN/q5FbHUA8in0ySCKb/WIrehI5H41EY5oeYXMi/3JD/Jv8c0AWKi knw/lxL5kncZ
4X6ntTopllBwCrLwyt1FOVVTO1QMnJwO9AEUcGHEkreZJ2OOF+g7VNRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVdh9pnZT/qoiMj+ 83X8hx/kVYqC
0+5ID94Svn8zj9MUAT0UUUAFFFFABRRRQAUUUUAQzxFsSRcSp0/2h6GpI5BL Grr0YZFOqCz/
AOPfPYu5H03HH6UAT0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAVXkzbTGYAmJ/wDWAfwn+9/jViigABDAFSCDyCKKgNu0RLWzBM8m Mj5T/hR9q2cT
xvH/ALWNy/mP64oAnopkc0cozHIrj/ZOafQAUUUEgDJIA96ACioDeQ5IRvMb 0jG7+VGJ5uv7
hPYguf6D9aAEnkLt5EJ+c/eYfwD1+vpU6IsaKijCqMAe1JHEkKbUXA6/WnUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFIzBFLMQ FAySTwBS1R1X
SotWtxFK8ibTlSjcZ916H8f0oGrX1DStVh1aB5YgV2OVKt1x2P4jB/TtV6uc 0XRZWmF9fh4p
4mKJHGxUEDjJxyQSOB0x65rU1iwn1KyENvdtbMHDEjOJAM/K20hsH2IPHpkE KmknoWNlrdM/
ywytG218YJVsA4PocEfnR9jh7B1/3ZGH8jVC2sJ20xbWMHRmik/5cfLdXGOo 3oeDnuoOR6db
1tbSwTTvJez3CytlY5VjCxDnhdqg45/iJPA98hBkJrWmyafqt4Bd7NLMwmja RtzCMsCVG7BB
KMAfY9MGtAS6UL/7EZrVr3G7yGkUyY9dpOa5vU/D+ov4avxZQg6hK19F5JdQ JoZpZCuTnAID
Kwz05HGTV7+z77/jw+yPj+0Ptn27emzb5/m7cZ37tvydMY74oA0JtesYtUs9 Ngnt5rmecwvE
ky74QI3fJUc/wY7da1a5WystSR/D9pLpzKmlynz7tpY8S/uJE3qAdx3MwJyA cnoeSN+2uLyX
7J59j5Pm25kn/ehvIk+XEfH3ur/MOPk9xQBboqK0kmms4JLmD7PO8atJDvD+ WxHK7hwcHjNS
0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAf/2Q==
--------------070006000502010004050701--
Re: Break between connection and ellipse [message #211627 is a reply to message #211606] |
Thu, 20 November 2008 07:09  |
Hi Stephan,
I don't know any implementation for polygons. I think, you can implement
it by yourself and contribute it to Eclipse in order to allow everybody to
reuse it in the future.
Best wishes,
Tanya.
> how is this done for polygons?
> I asked the same question earlier ("SlidableAnchor and custom polygon
> as NodeFigure") but didn't get an working solution.
> Stephan
> Tatiana Fesenko schrieb:
>> Hi Torsten,
>> We faced the same problem in UML2Tools. Collaboration and
>> CollaborationUse have ellipse shapes. All links were attached to the
>> accommodating rectangle, not to the ellipse by default.
>> Using org.eclipse.gmf.runtime.gef.ui.internal.figures.OvalFigure or
>> any other figure implementing IOvalAnchorableFigure interface in
>> XXXEditPart#createNodePlate() should help.
>> Best wishes,
>> Tanya.
>>> Hi,
>>> a break between the two figures. It looks like there is a invisible
>>> Greets
>>> Torsten
FUDForum. Page generated in 0.23833 seconds
