Error when open two revisions of local file in WTP Editor from Eclipse local history [message #211408] |
Tue, 01 April 2008 09:27  |
Following error occures when i trying to open two versions of same file
from eclipse local history.
Steps to reproduce
1) Create file *.html
2) modify and save file couple times
3) try open open one version of file
4) try to open second version of file(first version should be opened in
this time)
5) following error are will be trowed.
I use next environment:
Eclipse 3.3.2, WTP v2.01, WST v2.01.
This error are exist on Linux, Mac and Windows.
java.lang.IllegalArgumentException: no corresponding model info found
org.eclipse.wst.sse.ui.internal.StorageModelProvider.createD ocument(StorageModelProvider.java:336)
org.eclipse.ui.editors.text.StorageDocumentProvider.createEl ementInfo(StorageDocumentProvider.java:260)
org.eclipse.wst.sse.ui.internal.StorageModelProvider.createE lementInfo(StorageModelProvider.java:440)
org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(A bstractDocumentProvider.java:398)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:3931)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:190)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1225)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:168)
org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:2096)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:2994)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3012)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2617)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2739)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at org.eclipse.team.internal.ui.Utils.openEditor(Utils.java:983 )
at org.eclipse.team.internal.ui.Utils.openEditor(Utils.java:975 )
org.eclipse.team.internal.ui.actions.OpenRevisionAction$1.ru n(OpenRevisionAction.java:57)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:495)
org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:268)
org.eclipse.ui.internal.progress.ProgressManager.run(Progres sManager.java:1123)
org.eclipse.team.internal.ui.actions.OpenRevisionAction.run( OpenRevisionAction.java:67)
org.eclipse.team.internal.ui.history.LocalHistoryPage$8.hand leOpen(LocalHistoryPage.java:403)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1495)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1519)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1504)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 295)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3350)
at org.eclipse.swt.widgets.Control.sendTrackEvents(Control.java :2734)
at org.eclipse.swt.widgets.Control.kEventControlTrack(Control.j ava:1953)
at org.eclipse.swt.widgets.Widget.controlProc(Widget.java:367)
at org.eclipse.swt.widgets.Display.controlProc(Display.java:835 )
at org.eclipse.swt.internal.carbon.OS.CallNextEventHandler(Nati ve Method)
at org.eclipse.swt.widgets.Tree.kEventMouseDown(Tree.java:2363)
at org.eclipse.swt.widgets.Widget.mouseProc(Widget.java:1262)
at org.eclipse.swt.widgets.Display.mouseProc(Display.java:2819)
at org.eclipse.swt.internal.carbon.OS.SendEventToEventTarget(Na tive Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2938)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
FUDForum. Page generated in 0.04582 seconds
