Adding classpath entry to a JavaProject [message #211322] |
Mon, 01 August 2005 14:09  |
Originally posted by: a.c.seesing.gmail.com
I writing a plugin which shares a bit of itself with the code written inside it.
To do this, I want to make the plugin add itself to the classpath of the
JavaProject which uses it. For now I ask the user in a dialog to select the
correct *.jar file and then add that to the classpath.
But when I do that, it doesn't get added somehow, this is the code which I'm
currently using:
public void addRTInsectJAR(final IJavaProject project, final IProgressMonitor
monitor){
IPackageFragmentRoot[] roots;
try {
roots = project.getAllPackageFragmentRoots();
for (IPackageFragmentRoot root : roots) {
if(root.exists() && root.getElementName().equals(RTINSETCJAR)){
return;
// open a dialog for the user to select the rtinsect.jar
// and add it to the classpath
Display.getDefault().syncExec(new Runnable(){public void run() {
FileDialog dialog = new FileDialog(new Shell(Display.getDefault()), SWT.OPEN);
dialog.setFilterExtensions(new String[] {"*.jar"});
String result = dialog.open();
if(result == null)
return;
try {
IClasspathEntry[] entries = project.getRawClasspath();
IClasspathEntry[] newEntries = new IClasspathEntry[entries.length + 1];
newEntries[0] = JavaCore.newLibraryEntry(new Path(result), null, null, true);
System.arraycopy(entries, 0, newEntries, 1, entries.length);
project.setRawClasspath(entries, monitor);
} catch (JavaModelException e) {
// TODO Auto-generated catch block
e.printStackTrace();
If I check project.getResolvedClasspath() before and after my setRawClasspath
call, it stays the same.
My first question is: What am I doing wrong? And maybe someone can give me some
other useful tips about how to include plugin code inside a project.
Arjan Seesing
Re: Adding classpath entry to a JavaProject [message #212309 is a reply to message #211322] |
Fri, 12 August 2005 14:23  |
Originally posted by: noreply.gmx.de
Arjan Seesing schrieb:
> currently using:
> monitor){
> try {
> return;
> if(result == null)
> return;
> try {
> Arjan Seesing
as far as i can see, you do everything to get a new Array "newEntries"
with one more element than "entries", but then you write back "entries".
Ralf
FUDForum. Page generated in 0.03526 seconds
