| How to build BIRT from CVS Source? [message #211191] |
Fri, 12 January 2007 07:35 |
Originally posted by: brell.oio.de
how can i build BIRT 2.1.1 latest release RCP plugins from CVS source? I ve
checked out all projects and added required plugins to my workspace. Eclipse
builds binaries without errors and i can run the project as Eclipse
Apllication.
Now i want to rebuild all plugins to be able to export them to other Eclipse
RCP. I ve build webViewer with ANT build file first. Then i tried to run
BuildRCPUI.xml with correct property eclipse.home.
I get the following error:
generateBuildScript:
[echo] Executing target generateBuildScript,
eclipse.home=/D:/EclipseForBIRT/
[java] Buildfile: BuildDesignerCore.xml
[java] doGenerateBuildScript:
[java] BUILD FAILED
[java]
D:\EclipseForBirt\workspace\org.eclipse.birt.report.designer .core\BuildDesig
nerCore.xml:161: Unable to find element:
org.eclipse.birt.report.designer.core.
[java] Total time: 1 second
BUILD FAILED
D:\EclipseForBirt\workspace\org.eclipse.birt.report.designer .ui.rcp\BuildRCP
UI.xml:201: The following error occurred while executing this line:
D:\EclipseForBirt\workspace\org.eclipse.birt.report.designer .ui\BuildDesigne
rUI.xml:250: The following error occurred while executing this line:
nerCore.xml:166: Java returned: 13
FUDForum. Page generated in 0.02742 seconds
