Home » Language IDEs » ServerTools (WTP) » JSPs not compiling
JSPs not compiling [message #210816] Mon, 24 March 2008 18:25 Go to next message
Originally posted by: nick.poppelreiter.eyefinity.com
I just installed Eclipse Version: 3.3.2 Build id: M20080221-1800 - the
full install with web tools. I'm running a Tomcat 5.5 server in eclipse,
but I can't get my JSPs to compile. Nothing is showing up in my
...\workspace\.metadata\.plugins\org.eclipse.wst.server.core \tmp0\work\Catalina\localhost\ <context>
dir. Any suggestions???
Nick
Re: JSPs not compiling [message #210861 is a reply to message #210816] Tue, 25 March 2008 08:39 Go to previous messageGo to next message
> eclipse, but I can't get my JSPs to compile. Nothing is showing up in
> my
> ..\workspace\.metadata\.plugins\org.eclipse.wst.server.core\ tmp0\work\Catalina\localhost\ <context>
> Nick
Provide more detail about what you are doing and what the result is?! :)
Larry
Re: JSPs not compiling [message #210877 is a reply to message #210861] Tue, 25 March 2008 10:15 Go to previous messageGo to next message
I'm running a tomcat server in eclipse. Servlets (with appropriate
web.xml mapping) are working just fine. But JSPs are not. I think it's
because they are not compiling - there are no java or class files for
them. The java and class files should be in tmp0 (the server path) in the
work\Catalina\localhost\<contextroot> directory.
Re: JSPs not compiling [message #210885 is a reply to message #210877] Tue, 25 March 2008 10:24 Go to previous messageGo to next message
> the work\Catalina\localhost\<contextroot> directory.
Unfortunately, no JSP related java or class file showing up under the
work directory provides almost nothing with which to make a diagnosis.
Just shooting in the dark, a simple way to achieve this behavior is to
have a typo, or some other error, in the URL used such that no JSP is
actually invoked.
Larry
Re: JSPs not compiling [message #210892 is a reply to message #210885] Tue, 25 March 2008 10:38 Go to previous messageGo to next message
I thought the java and class files get created when the server publishes.
Not so?
Re: JSPs not compiling [message #210898 is a reply to message #210892] Tue, 25 March 2008 10:54 Go to previous messageGo to next message
> publishes. Not so?
You are correct. However, this fact contains no clues as to why these
files aren't showing up.
Larry
Re: JSPs not compiling [message #210907 is a reply to message #210898] Tue, 25 March 2008 11:00 Go to previous messageGo to next message
My web.xml file contains the following, where my context root is
valuereport:
<servlet>
<description></description>
<servlet-name>ValueReport2</servlet-name>
<jsp-file>/ValueReportMain.jsp</jsp-file>
</servlet>
<servlet-mapping>
<url-pattern>/ValueReportMain</url-pattern>
</servlet-mapping>
The ValueReportMain.jsp file is located in the WEB-INF dir in my
workspace, along with my web.xml file. Both are getting published to the
server tmp0 WEB-INF dir. At this point in testing, my jsp file only
contains minimal html.
My URL is:
http://localhost:8080/valuereport/ValueReportMain
Re: JSPs not compiling [message #210915 is a reply to message #210907] Tue, 25 March 2008 11:07 Go to previous messageGo to next message
> valuereport:
> <servlet>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> the server tmp0 WEB-INF dir. At this point in testing, my jsp file only
> My URL is:
Try:
<jsp-file>/WEB-INF/ValueReportMain.jsp</jsp-file>
The "path" to the resource needs to start from the "root" of the webapp.
Access to resources under "WEB-INF" is forbidden to the browser, but
that doesn't apply to internal uses like this.
Larry
Re: JSPs not compiling [message #210922 is a reply to message #210915] Tue, 25 March 2008 11:14 Go to previous message
OK. That's what I was after. How much do I owe you? :) Guess this is
the benefit of web forums! Thanks much.
Nick
Previous Topic:Derby version and Eclipse version?
Next Topic:Missing Contents of WEB-INF directory
Current Time: Wed Jul 16 17:27:02 EDT 2025
Powered by FUDForum. Page generated in 0.06869 seconds
