Home » Eclipse Projects » Eclipse Platform » National Language Support
National Language Support [message #210629] Fri, 12 March 2004 12:08 Go to next message
I have externalized strings for a plugin into a properties bundle that
resides in the same package/directory as the class that references it.
The properties file is named fred.properties and it sits in my plugin's
package directory com.nls.fred
What do i have to do in order to use the plugin fragment architecture to
hold translations of this properties file? Do i have to change any code
that accesses the bundles and in which plugin fragment directory should
the translated properties file be placed?
The doc seems to indicate you can do this, but I couldn't figure out how
to make it work.
Thanks.
- Chris
Re: National Language Support [message #210691 is a reply to message #210629] Fri, 12 March 2004 15:22 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
So, it doesn't work?
What exactly?
Sam Mesh - http://openrules.com
Re: National Language Support [message #210704 is a reply to message #210629] Fri, 12 March 2004 16:23 Go to previous message
Originally posted by: manahan.NOSPAM.ca.ibm.com
The docs for fragment use the NL translation of strings as a use of
fragments as an example.
Help->Help Contents.search on "fragment". Should see a "German Fragment
Example"
Peter
> to make it work.
> Thanks.
> - Chris
Previous Topic:how to add buttons to bottom of Wizard
Next Topic:CVS operations spew out errors into .log
Current Time: Sun Sep 07 15:53:34 EDT 2025
Powered by FUDForum. Page generated in 0.03021 seconds
