| How do you start to write a GEF application? [message #20345] |
Tue, 24 September 2002 17:45  |
I am a newer here. I played around the GEF sample application, such as
Logic Editor. I wonder how do you start to write a GEF application? Do
you just start coding line by line, from scratch? Is there any template
that I can use?
Thx,
John
| Re: How do you start to write a GEF application? [message #20786 is a reply to message #20774] |
Wed, 25 September 2002 16:37  |
No. You should just use it as an example. It basically has the bare minimum
needed to get an editor up and running. There is no save support in it. There
is no support for connections. I don't even think there's an outline view.
There _is_ a palette, which actually isn't required. (If you don't want/need a
palette, you can subclass GraphicalEditor instead of
GraphicalEditorWithPalette.)
As always, if you have any specific implementation questions, feel free to ask.
We're here to help.
Eric
"John Smith" <draw2d@yahoo.com> wrote in message
news:3D921954.DBE92F76@yahoo.com...
> Do you suggest that I use the Shapes plugin as a template?
> Thx,
> John
> Eric Bordeau wrote:
> > You might want to check out the Shapes plugin.
> > http://eclipsewiki.swiki.net/50#shapeeditor It's a bare-bones editor that
> > doesn't really do anything, but it can help you get started.
> > news:3D90DD04.72B3DD28@yahoo.com...
> > > Hi,
> > > that I can use?
> > > Thx,
> > > John
FUDForum. Page generated in 0.04268 seconds
