Home » Language IDEs » ServerTools (WTP) » Problems debugging servlets
Problems debugging servlets [message #20340] Mon, 26 April 2004 15:28 Go to next message
Originally posted by: john.macintyre.ca
I am very new to Java, Eclipse, and Tomcat. And I'm having alot of problems
with configuration.
Java - j2sdk1.4.2_04
Tomcat - v5.0.19
Eclipse - v2.1.3
Sysdeo Eclipse Tomcat Launcher plugin - v2.2.1
The plug in has an option for the Tomcat version in Preferences > Tomcat >
Tomcat Version. Which to me implies it will work with Tomcat 5.
When I try to start Tomcat from the plug in, I get a series of errors ...
with the following being the most suggestive (imho).
java.lang.ClassNotFoundException: org.apache.catalina.loader.DevLoader
So I installed "devloader.zip" into "TOMCAT_HOME/server/classes". The
readme for devloader.zip says it is only for Tomcat version 4. I decide to
try it anyway; Tomcat starts successfully, but when I go to start the
servlet ... I get this:
Exception occurred during launch
Reason:
Failed to connect to remote VM. Connection refused.
So ... can I run this with Tomcat 5? Should I uninstall Tomcat 5 (again)
and install v4 this time? Am I missing something completely obvious that's
well documented and makes me look like a complete fool? ;-)
Thanks in advance,
John
Re: Problems debugging servlets [message #20360 is a reply to message #20340] Mon, 26 April 2004 17:53 Go to previous messageGo to next message
John:
When I had any problems with the Sysdeo Eclipse Tomcat plugin, it was
because I was running the JRE and not JDK. This because Tomcat plugin
needs access to the tools.jar. What you might try is to use the -vm
opition and force Eclipse to use the JDK.
I'd also suggest looking at the MyEclipseIDE, http://www.myeclipse.com.
HTH,
Jeff
John MacIntyre wrote:
> with configuration.
> Tomcat - v5.0.19
> Eclipse - v2.1.3
> Reason:
> Thanks in advance,
> John
Re: Problems debugging servlets [message #20380 is a reply to message #20360] Mon, 26 April 2004 20:23 Go to previous message
Originally posted by: scott.anderson.genuitec.com
Jeff,
Thanks for the recommending MyEclipse. However, the URL was mildly
misstated. The correct one is http://www.myeclipseide.com.
--Scott
"Jeff Duska" <Jeff.Duska@noaa.gov> wrote in message
news:c6k01d$a78$1@eclipse.org...
> John:
> HTH,
> Jeff
> > Hi,
problems
> > with configuration.
> > Tomcat - v5.0.19
> > Eclipse - v2.1.3
to
> > Reason:
(again)
that's
> > Thanks in advance,
> > John
Previous Topic:Tutorials for debugging servlets - newbe question
Next Topic:Eclipse, JWS Tutorial, and Ant
Current Time: Wed Oct 29 01:46:14 EDT 2025
Powered by FUDForum. Page generated in 0.04020 seconds
