Home » Language IDEs » C / C++ IDE (CDT) » CDT errorparser for Microsoft compiler
CDT errorparser for Microsoft compiler [message #210343] Mon, 25 February 2008 05:49
Originally posted by: spetersen.harmanbecker.com
I have a project created in the default location, and the directories, which
contain the source-code linked into the project. The build-environment is
Jam, and to get the compiler run, there is a Win32 *.cmd-file started. when
a compile-error does occure, most times the error is not displayed correctly
in the Problems-view of Eclipse. This happens even with two files located in
the same (linked) directory with the same compile-error. For one of the two
files the columns are filled out correctly, for the other file the
CDT -errorparser is not able to fill out the columns in the right way.
Is this a known isuue?
Stefan
Previous Topic:How to Debug a JNI DLL using CDT?
Next Topic:how to delete single paths
Current Time: Sun Aug 31 14:25:05 EDT 2025
Powered by FUDForum. Page generated in 0.10266 seconds
