Home » Eclipse Projects » Remote Application Platform (RAP) » Demo Problems
Demo Problems [message #20271] Wed, 25 April 2007 10:40 Go to next message
Originally posted by: manuel.staechele.levante-software.ch
i just want to test rap.
so i download eclipse 3.2.2
download via cvs rap projekt (File->Import->Team->and so on)
then i want run the demo, and i follow the description on:
http://www.eclipse.org/rap/cvs.php
run -> run-> Equinox OSGi Framework -> RAP-Demo
in the console appears only:
osgi>
noting else.
i test to start the demo manually
start org.eclipse.rap.demo
results in error, similiar:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.platfor m.doc.isv/porting/3.2/incompatibilities.html?revision=1.14#c onfigIni
so i go to Run -> Run -> Equinox OSGi Framework -> RAP-Demo
and clicked on the plugins listed
than i click again run
also only
osgi>
in the console.
now can i typeing in again the start org.eclispe.rap.demo
result: output noting and still osgi> in the console.
always i can not access the demo over
localhost/rap
i also test
localhost:10080/rap (bevor changed the attribute)
so many thanks for your hints.
and sorry for my poor english
greetings
manuel
Re: Demo Problems [message #20342 is a reply to message #20271] Thu, 26 April 2007 05:27 Go to previous message
Originally posted by: fappel.innoopract.com
if you see only the osgi> prompt the jetty engine didn't start up. You may
type ss into the console and may get a trace like this:
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.2.R32x_v20070118
1 ACTIVE javax.servlet_2.4.0.qualifier
2 ACTIVE org.apache.xerces_2.8.0.v200606131651
3 ACTIVE org.eclipse.core.commands_3.2.0.I20060605-1400
4 RESOLVED org.eclipse.core.contenttype_3.2.0.v20060603
5 ACTIVE org.eclipse.core.jobs_3.2.0.v20060603
6 ACTIVE org.eclipse.core.runtime_3.2.0.v20060603
7 RESOLVED
org.eclipse.core.runtime.compatibility.registry_3.2.1.R32x_v 20060907
Master=13
8 ACTIVE org.eclipse.equinox.common_3.2.0.v20060603
9 INSTALLED org.eclipse.equinox.http.jetty_1.0.0.qualifier
10 ACTIVE org.eclipse.equinox.http.registry_1.0.0.qualifier
11 ACTIVE org.eclipse.equinox.http.servlet_1.0.0.qualifier
12 ACTIVE org.eclipse.equinox.preferences_3.2.1.R32x_v20060717
13 ACTIVE org.eclipse.equinox.registry_3.2.1.R32x_v20060814
Fragments=7
14 ACTIVE org.eclipse.equinox.servlet.api_1.0.0.v20060601
15 ACTIVE org.eclipse.osgi.services_3.1.100.v20060601
16 ACTIVE org.eclipse.rap.demo_1.0.0.qualifier
17 ACTIVE org.eclipse.rap.jface_1.0.0.qualifier
18 ACTIVE org.eclipse.rap.rwt_1.0.0.qualifier
19 ACTIVE org.eclipse.rap.ui.workbench_1.0.0.qualifier
20 ACTIVE org.eclipse.rap.w4t_1.0.0.qualifier
21 INSTALLED org.mortbay.jetty_5.1.11.qualifier
osgi>
As you can see the jetty bundle has only been INSTALLED not ACTIVE. Go to
Run -> Run -> Equinox OSGi Framework -> RAP-Demo and click 'Validate Plug-in
Set'. If problems are detected click 'Add Required Plug-ins'. After that
validate again and if the problems have vanished click run. If not call in
again...
Ciao
Frank
"Manuel Staechele" <manuel.staechele@levante-software.ch> schrieb im
Newsbeitrag news:f0np7l$7cs$1@build.eclipse.org...
> osgi>
> noting else.
> also only
> osgi>
> in the console.
> localhost/rap
> i also test
> greetings
> manuel
Previous Topic:How to deploy a webservice in a RAP architecture
Next Topic:RAP in WAP
Current Time: Wed Nov 12 12:34:47 EST 2025
Powered by FUDForum. Page generated in 0.28140 seconds
