Home » Newcomers » Newcomers » Problem while making new java class
Problem while making new java class [message #209865] Wed, 09 May 2007 05:59 Go to next message
Originally posted by: hussam_benz.yahoo.com
I tried to create new java class and I check "Generate Comments"
I got Error Message Box, written inside it
Creation of element failed
Reason:
some charachters cannot be mapped using "Cp1252" charachter encoding.
Either change the encoding or remove the characters which are not
supported by the "Cp1252" character encoding
So I've opened Preferences then General then workspace to check "Text file
Encoding" , the default value was "Cp1256" I checked other encoding schema
I didn't find "Cp1252".
Still I didn't give up
I searched on the local hardisk for files "Cp1252".
I found few files carry the same encoding name then I copied them to
this directory
C:\Program
Files\Eclipse\workspace\.metadata\.plugins\org.eclipse.help. ui\scope_sets
Then I closed Eclipse and I ran it again then I checked "Text file
Encoding" from preferences. I found "Cp1252" encoding schema, I choosed
immediatly then I tried to create new java class with "generate comments"
I got the same exeption.
Please if you know a solution send it to me
Re: Problem while making new java class [message #209868 is a reply to message #209865] Wed, 09 May 2007 06:12 Go to previous message
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Hi Hossam
This behavior is because you have probably in comments national
characters. I suggest you to go to preferences->general->workspace and
set UTF-8 as default.
HTH,
Chris
Previous Topic:java.lang.NoClassDefFoundError: ..Exception in thread "main":
Next Topic:Installing TPTP 4.3.1
Current Time: Thu Jul 17 22:04:25 EDT 2025
Powered by FUDForum. Page generated in 0.09328 seconds
