Home » Newcomers » Newcomers » java.lang.NoClassDefFoundError: ..Exception in thread "main":
java.lang.NoClassDefFoundError: ..Exception in thread "main": [message #209860] Wed, 09 May 2007 05:42
Originally posted by: mukerji.nita.gmail.com
I have Eclipse SDK 3.2.1 and Jdk 1.6.In the Java preference platform upon
running the following java class :
package cnvpth;
public class ConvertPath {
public static void main(String args[]){
char ch;
int i,k=0;
gives java.lang.NoClassDefFoundError: ..Exception in thread "main": I have
run other java class from within a plug-in.They have run fine.Where could
I be going wrong in this?May be I should try running from DOS prompt and
see if the same happens(OS is Windows XP).At collage (where I try the same
things that I try here) under os Linux,I tried to run the java class from
shell,there too it gave the same error.
Previous Topic:Another icons question :-)
Next Topic:Problem while making new java class
Current Time: Mon Nov 10 23:09:42 EST 2025
Powered by FUDForum. Page generated in 0.07858 seconds
